[mapguide-users] Raster Tiling - rasterconfig.php
Saso saso at sl-king.si
Wed Jan 16 04:18:04 EST 2008
After your suggestion to look jasons rasterconfig.php script, we found out,
that script only work with extensions with non-capital letters.
So in my case there was 2 raster image file extension with .tif and other 4
with .TIF
We added value .TIF to rasterconfig.php in line 24:
define ("IMAGEEXT", "/(png)|(jpg)|(tif)|(tiff)|(ecw)|(sid)|(gif)|(TIF)/");
Thank you Frank, for help me out.
Kind regards,
Sašo
Frank Warmerdam-2 wrote:
> Saso wrote:
>> In MGOS 1.2 with FDO 3.2.3 i have used raster config file utility:
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes .
>> Problem is, that only part from 80 raster images (tif/tfw) are shown in
>> mgos, if i use config file utility.
>> In enlclosed config file where you can see only 2 images defined, the
>> other
>> 4 are not in config.xml.
>>   http://www.nabble.com/file/p14874242/raster%2Btile%2Bconfig.txt
>> raster+tile+config.txt
>> If i don't use config file utility, all images are shown in mgos.
>> TFW files from images that are and aren't in config.xml looks similar.
>> What could be the reason, raster tile index not including all image
>> files?
> Saso,
> Just to be clear, the problem you are encountering is that the config
> file utility is not adding all the raster files to your configuration
> file, right?
> Assuming that is true, I'd suggesting adding some extra debug output to
> Jason's rasterconfig php script to see if all expected files are being
> processed by it, and if not why.  For instance, is readdir() returning
> all the files?  Is there some issue with the extension test?  Is
> the scExtentByteReader NULL unexpectedly?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Raster-Tiling---rasterconfig.php-tp14874242s16610p14875209.html
