[mapguide-users] Alternative to AutoDesk MagGuide Studio
Jason Birch Jason.Birch at nanaimo.ca
Wed Jan 16 13:40:55 EST 2008
Do you also have 1.1 installed?  If not, you will need to.  Note, this
shouldn't downgrade you; 1.1 and 2.0 can live together in relative
harmony.
If you are installing on an IIS server and installing 1.1 messes up your
2.0 installation (I haven't tried this myself; it might work fine) you
can just run the config script to re-set it.
http://msdn2.microsoft.com/en-us/library/k6h9cz8h(VS.80).aspx
aspnet_regiis -i
Jason
-----Original Message-----
Subject: Re: [mapguide-users] Alternative to AutoDesk MagGuide Studio
It doesn't work with installed .NET framevork 2.0.  Is there any
solution without framework downgrade?
