[mapguide-users] Fusion
Berdel, Brian brian.berdel at mcmtrans.com
Fri Jan 18 08:44:56 EST 2008
OK, thanks for the update.
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer
Sent: Friday, January 18, 2008 8:14 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Fusion
Brian,
The fusion package included in beta 2 probably has some outstanding
problems that have already been fixed (in particular, the templates
needed some love).  I don't recall an issue with toggling layer
visibility, but I would rather have you test the latest version before
we investigate further.
We have a short list of important defects to resolve and then we will be
posting a separate package with Fusion that can be used to update beta 2
to the latest version.  At this point, I recommend waiting a few days
for us to post this and then try this again.
Cheers
Paul
On 17-Jan-08, at 3:27 PM, Berdel, Brian wrote:
> Ok, I must be missing something when trying the samples...Please help.
> I was using IIS and the .NET config, but now I am using bundled php
> -Brand new computer XPsp2
> -Mapguide 2.0 Beta2 just installed with the bundled php config
> -I loaded the Sheboygan Sample Data and the Fusion Sample package.
> As far as I can tell, this is all I should need to do.
> I then went to
> http://localhost:8008/mapguide/fusion/templates/mapguide/slate/index.h
> tm l?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan
> %2fFlexibleLa
> youts%2fSlate.ApplicationDefinition
> The application loads, but it does not load the district layer, the
> scale textbox is all the way to the left, and the layers do not turn
> on or off...Zooming, Selecting, etc does work.
> What is going on?  Is that all I need to do?
> Brian  Berdel
> p: 215.283.9444
> www.mcmtrans.com
> From: mapguide-users-bounces at lists.osgeo.org
> Spencer
> Sent: Wednesday, January 16, 2008 10:15 PM
> Hi Bill,
> Fusion is designed to work with other scripting languages on the
> server side but porting the existing scripts to the other languages
> has not been done.  This would be an ideal candidate for contributions
> to the open source community.
> Cheers
> Paul
> On 10-Jan-08, at 8:06 AM, Kimbrell, Bill wrote:
>> Are there plans for Fusion to work with .NET?
>> And if so, any idea of dates ?
>> Thanks, Bill Kimbrell
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike
>> Adair
>> Sent: Wednesday, January 09, 2008 5:17 PM
>> Fusion will only work with PHP at this point.
>> For the layer toggling issue, I'm not seeing this bug. Are you using
>> a
>> tiled map? If so, layer toggling won't work because the tiles are
>> served
>> up with layers on or off as specified by the mapguide server. If
>> you're not using a tiled map, is there a public instance of your app
>> that we can look at?
>> Mike Adair
>>> Not getting much of a response here...So I'll try another question.
>>> Does Fusion work with the .NET configuration of IIS or PHP only? I
>>> have tried it the samples on multiple machines and cannot get it to
>>> work. Has anyone got it to work with .NET?
>>> *From:* mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
>>> *Berdel,
>>> Brian
>>> *Sent:* Wednesday, January 09, 2008 1:11 PM
>>> *To:* MapGuide Users Mail List
>>> *Subject:* RE: [mapguide-users] Fusion - Layers do not turn off / on
>>> Some layers actually never load on the samples, and I noticed in
>>> firefix that the status bar says "transferring data from local host"
>>> it just hangs there...
>>> Any ideas?
>>> *Berdel,
>>> Brian
>>> *Sent:* Wednesday, January 09, 2008 10:10 AM
>>> Is everyone else's working correctly? Just wondering if it is
>>> something I did, or didn't do...If I view a map in a regular viewer
>> the
>>> layers work as they are supposed to...However, if I view a fusion
>> sample
>>> or one of my maps in fusion, they do not respond to the
>>> checkboxes...
>>> If I try to turn them on or off, nothing happens...
>>> *Berdel,
>>> Brian
>>> *Sent:* Tuesday, January 08, 2008 4:58 PM
>>> *Subject:* [mapguide-users] Fusion - Layers do not turn off / on
>>> Just started testing fusion and 2.0...Is anyone else having issues
>> where
>>> their layers will not turn on or off once the map is loaded?
>>> The fusion samples load up correctly, but when I attempt to turn a
>>> layer on or off, the screen just flashes and nothing happens. The
>>> other normal mapping functionalities are available.
>>> Thanks,
>>> -Brian
>>> *Berdel,
>>> Brian
>>> *Sent:* Tuesday, January 08, 2008 4:42 PM
>>> *Subject:* [mapguide-users] Symbols 2.0
>>> Sorry if this is a known issue, but I did a quick search and
>>> couldn't
>>> find anything...
>>> All of my symbols are appearing on top of each other in the lower
>>> left
>>> hand corner of my map in 2.0 beta2. Anyone else?
>>> Thanks,
>>> Brian
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Marc
>>> Pfister
>>> *Sent:* Tuesday, January 08, 2008 3:31 PM
>>> *Subject:* RE: [mapguide-users] Mapguide with no map...
>>> I am using the Sheboygan data, and I checked the extents and they
>>> are
>>> correct. I'm confused as to why the Sheboygan dataset is throwing
>>> "Unsupported coordinate system code" when I'm trying to output to
>>> 4326. That shouldn't happen.
>>> *Kenneth, GEOGRAF A/S
>>> *Sent:* Tuesday, January 08, 2008 12:06 PM
>>> *Subject:* Re: [mapguide-users] Mapguide with no map...
>>> You should try with some data that you know the bounds of (Sheboygan
>>> perhaps?).
>>> I have seen many cases, where the auto-calculated map extents are
>> wrong.
>>> Regards, Kenneth, GEOGRAF A/S
>>> Marc Pfister skrev:
>>> The MG error log doesn't show any errors. The Admin log only shows
>>> successes.
>>> I did manage to generate an error message of sorts. If I use
>>> MapAgent
>>> to generate a WMS GetMap request, using the default values it gives
>>> for the Sheboygan dataset ( EPSG 4326 and lat lon bounds in the -87,
>>> 43 range), I get this error:
>>> The coordinate system conversion failed.
>>> Unsupported coordinate system code. The coordinate system conversion
>>> failed.
>>> Exception occurred in method
>>> MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 972 in
>>> file CoordinateSystem/CoordinateSystem.cpp
>>> Proj is the bin folder, and executing ./proj returns the useage:
>> message.
>>> I'm not sure what's going on, and without any more clues I might
>>> just
>>> reinstall and see what happens.
>>> <mailto:mapguide-users-bounces at lists.osgeo.org>
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Ivan
>>> Milicevic
>>> *Sent:* Monday, January 07, 2008 11:55 PM
>>> Anything in MG server log???
>>> Pfister
>>> *Sent:* Tuesday, January 08, 2008 1:50 AM
>>> *To:* mapguide-users at lists.osgeo.org
>>> <mailto:mapguide-users at lists.osgeo.org>
>>> *Subject:* [mapguide-users] Mapguide with no map...
>>> I recently installed Mapguide OS on Ubuntu using the wiki pages and
>>> everything seemed to install correctly.
>>> Apache starts and responds fine. I get directory listings and simple
>>> pages or parts of pages.
>>> Mapguide starts fine. Watching the output from starting the startup
>>> shell script, it says it starts up and is using the Proj 4 library.
>>> Map Admin works fine. I can load data packages, etc
>>> However, I can't seem to get any map output.
>>> WebStudio works, though never draws any sample maps (though it only
>>> wants to look at 127.0.0.1, which isn't the right place to look on
>>> my
>>> system)
>>> The sample maps, like Sheboygan, don't seem to draw anything. I get
>>> a
>>> blank page in the brower when I use the phpviewersample.
>>> MapAgent works for requests like GetCapabilities, but also doesn't
>>> draw any maps with the related tools. I don't know the extents of
>>> the
>>> sample data, so maybe that's why I can't get an output from it.
>>> In any case, I never see any error messages show up at the terminal.
>>> Is there a way to make it more verbose?
>>> My next step will be to load a sample shapefile of which I know the
>>> extents so I can give it more complete request for an area to
>>> render.
>>> Are there any other troubleshooting steps I should take?
>>> n
>>> Marc Pfister
>>> Geospatial Data Manager
>>> ENPLAN
>>> mpfister at enplan.com <mailto:mpfister at enplan.com> 530/221-0440 x108
>>> 530/221-6963 Fax
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org <mailto:mapguide-
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
