[mapguide-users] ePLot to DWF
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Jan 21 10:59:42 EST 2008
I use it often (PHP) and it works well. It's the only way to print to
scale, when using the DWF Viewer rather than AJAX (since the DWF Viewer
print method has some sort of scaling bug). I took the PHP examples and
modified them to fit my needs, and it works fine. That's with Design
Review, but I believe it also worked before I had installed Design
Review. I do remember that the samples have some stuff hard-coded, like
map names, etc. You'll need to change those to fit your needs, or else
modify the code to get that info from the session.
Andrew
Berdel, Brian wrote:
> Haven't really looked deep into it but I tried the Plot to DWF sample in .NET on 1.2 and it did not work...just a blank page.  I stepped through the code and there were no errors.
> I then tried the online PHP sample and I received an error that said the file was not a valid dwf when opening...Tried on a couple machines.  Also tried with Design Review installed, and the older dwf viewer.
> Anyone else?
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Manuel C G
> Sent: Monday, January 21, 2008 2:12 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] MGOS 2.x
> SI, no hay problema, salvo un fichero .dll que tienes que copiar en el
> directorio una vez instalado.
> YES, no problem, you have to overwrite a .dll file in the install directory.
> Ricardo Medrano wrote:
>> Perdón amigos:
>> Me olvida de un punto que para mí es muy importante la version MGOS
>> 2.xpuede ser trabajada con el mapguide studio 2007?
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
