[mapguide-users] Issue with Google Maps Mashup with Mapguide
Andy Morsell amorsell at spatialgis.com
Mon Jan 21 13:51:18 EST 2008
Okay, so it looks like you are using some of the Google Earth files and
trying to adapt them to work with Google Maps..... It's starting to make
more sense now.
Are you getting any error messages when you open that file by itself in a
browser?  If not, do you have debugging turned on in PHP?  You have the line
that would write the marker elements commented out so you definitely aren't
going to get valid XML, but are you seeing any output with the echo line on
line 40?  Is your field called TEST a valid field in the IBI feature source?
Andy
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of javed shaikh
Sent: Monday, January 21, 2008 10:34 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Issue with Google Maps Mashup with Mapguide
Hello Andy
Yes I am using the file which you have provided with the application. I am
tring to generate the same functionality of creating KML and providing the
same to Google Map instead.
Attached is the file I am using
Javed
> From: amorsell at spatialgis.com
> To: mapguide-users at lists.osgeo.org
> Date: Mon, 21 Jan 2008 09:37:25 -0800
> Is MuniMarkers.php a file that you wrote or a file you obtained somewhere?
> It sounds similar to a file I supplied with a class on MapGuide Open /
> Google Earth (not Google Maps) integration. Can you attach the file and
> send it to me? Thank you.
> Andy
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of JavedPune
> Sent: Monday, January 21, 2008 4:10 AM
> Hello Andy Morsel
> Thank you very much for quick reponse. I tried refering to your suggested
> site but my basic problem is like you mentioned It sounds like your
> MuniMarkers.php page is not returning valid XML.
> I am unable to understand why it is not returning the XML. I tried opening
> the MuniMarkers.PHP in browser it gives following error 'X-Powered-By:
> PHP/5.2.1 Content-type: text/html '
> I would appricieate if you could extend a bit extra help in this matter.
> Regards
> Javed S
http://www.nabble.com/Issue-with-Google-Maps-Mashup-with-Mapguide-tp14950884
> s16610p14995999.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
  _____
Post free auto ads on Yello Classifieds now! Try it now!
<http://ss1.richmedia.in/recurl.asp?pid=255>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080121/0a926683/attachment.html
