[mapguide-users] Problem whit generate kml from mapguide.
Zac Spitzer zac.spitzer at gmail.com
Tue Jan 22 10:09:08 EST 2008
Mapguide currently does this stupid silent fall back and returns whole
featuresource without the
filter if the filter fails.....which would explain this, unpredictably
frustrating huh?
z
On Jan 23, 2008 1:57 AM, Maciej Skorczewski <maciej.skorczewski at procad.pl>
wrote:
> Hi!
> I wrote aplication who generate kml files.
> all work fine but i have problem whit some polygons (and use API to get
> coords of this polygon)
> some screenshot
> http://img179.imageshack.us/img179/1966/41289677tu3.png
> The problem is: when i try to get coords of polygon nr.1 (in this place
>  are two object-polygon in one source after use filter guery)
> ex. i use
> $featureReader->ReadNext() ...and MG show me 2 polygons
> (1 polygon)
> (second polygon)
> can't get any coords of this.
> the code is
> ______________
> $featureService =
> $siteConnection->CreateService(MgServiceType::FeatureService);
> $queryOptions = new MgFeatureQueryOptions();
> $queryOptions->SetFilter("FID > 253");
> $featureReader = $featureService->SelectFeatures(new
> MgResourceIdentifier($x_adress),$x_layer, $queryOptions);
>        $geometryReaderWriter = new MgAgfReaderWriter();
> // this is loop on FID > 1(next are 2,3,4,...)
>        while ($featureReader->ReadNext())
>                $muniName = $featureReader->$a7_1($a7_0);
>                $byteReader = $featureReader->GetGeometry('Geometry');
>                $geometry = $geometryReaderWriter->Read($byteReader);
>                $point = $geometry->GetCentroid();
>                $x = $point->GetCoordinate()->GetX();
>                $y = $point->GetCoordinate()->GetY();
>                echo '<Placemark>';
> // This can be a bug...
> // question: how to know that there are 2 object-polygon
> // and $linearRing get coords of first the second, polygon object.
>                $linearRing = $geometry->GetExteriorRing();
>                $coordIter = $linearRing->GetCoordinates();
>                echo'<MultiGeometry>';
>                echo'<Polygon>';
>                echo'<outerBoundaryIs>';
>                echo'<LinearRing>';
>                echo'<coordinates>';
> // So when loop is in 1. iterate it show 2 object polygons.
> // ...and MG don't show any coords
>                while ($coordIter->MoveNext())
>                        $coord = $coordIter->GetCurrent();
>                        if ($coord != null)
>                         $coord->GetX().",".$coord->GetY().",0 ";
>                echo'</coordinates>';
>                echo'</LinearRing>';
>                echo'</outerBoundaryIs>';
>                echo'</Polygon>';
>                echo'</MultiGeometry></Placemark>';
>        $featureReader->Close();
>        echo '</Document></kml>';
> thx for any help.
> maciek
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080123/0f3fe8c1/attachment.html
