[mapguide-users] HTTP/1.1 559 MgFdoException after displaying largeraster layer
Andy Morsell amorsell at spatialgis.com
Wed Jan 23 12:24:19 EST 2008
I see almost identical symptoms with a client, but in my case, they are
using MapGuide Enterprise 2008 with the ATIL raster provider.  After
accessing raster based unmanaged datasources of ECW's (about 10 GB total),
all SDF based layers fail until the service is restarted.  The error log
file yields something like:
4272|1044) An exception occurred in FDO component.
SDF connect failed. File does not exist or cannot be opened in specified
access
mode.
Exception occurred in method MgFdoConnectionManager.Open at line 979 in file
c:\
build_bond_area\Bond_Nightly\BUILD_41.3\Ent\OS\Server\src\Common\Manager\Fdo
Conn
ectionManager.cpp
We also have other issues with MrSID and TIF directories with the server
eventually just failing to render any raster based layers.  In our case,
Autodesk is well aware of the issues and is working on fixes.  Additionally,
it sounds like this is not an isolated issue and many customers are having
similar problems with the raster provider.
I do  find it interesting that this problem is happening in your case with
MGOS 1.2 and the GDAL provider which indicates that this may be more of a
lower-level FDO issue.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nclayton
Sent: Wednesday, January 23, 2008 6:20 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] HTTP/1.1 559 MgFdoException after displaying
largeraster layer
I changed the subject to reflect the latest details on my issue.
Here are the specifics of the issue:
I have a layer for raster images that I have named "aerial". This layer
points to a folder on the server that contains 594 ecw files that total
17.6GB in size.
I have the max visible range for this layer set to 1:20,000 to reduce the
amount of raster information that has to be displayed.
I have code to toggle a layer on and off, which works fine. Once I toggle
the aerial layer on though, I start getting the HTTP/1.1 559 response from
mapagent.fcgi. This causes none of my SDF based layers to load. I still see
the raster layer (when toggled on) and text layers which pull from a
database.
The full text of the response is:
<html>
<head>
<title>MgFdoException</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"> </head>
<body> <h2>An exception occurred in FDO component.
access mode. </h2> An exception occurred in FDO component.
access mode.
c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\com
mon\manager\FdoConnectionManager.cpp
</body>
</html>
I continue getting this error even after I toggle the aerial layer off.
Thank you all for your help.
View this message in context:
http://www.nabble.com/Changing-Visibility-for-one-layer-affects-others-tp150
21169s16610p15042666.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
