[mapguide-users] Fusion support in MapStudio OS
Paul Spencer pagameba at gmail.com
Tue Jan 29 08:44:33 EST 2008
Brad,
Fusion will work with older versions of MapGuide but you cannot store
the ApplicationDefinition in the server.  This means that tools like
MapStudio will not allow you to edit ApplicationDefinition resources
on older versions  of MapGuide.  You have to edit them by hand and
store them with the index.html file (the templates have example
ApplicationDefiniton files that should work if you just load the
index.html file without supplying an application definition path in
the Library).
Cheers
Paul
On 28-Jan-08, at 12:57 PM, BradM wrote:
> Does MapStudio work with Mapguide 2007 and the latest version of
> Fusion?  Do
> you have a demo website that I can have a look at?
> thanks
> Kenneth, GEOGRAF A/S wrote:
>> I have placed an updated version of MapStudio Open Source at:
>> http://code.google.com/p/mapstudioos/
>> The new version supports creating and editing Fusion applications.
>> Feedback is appreciated, and you may post feedback on the issue
>> tracker
>> found on the page.
>> Regards, Kenneth, GEOGRAF A/S
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Fusion-support-in-MapStudio-OS-tp15124907s16610p15141047.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
