[mapguide-users] How to embed the map in my own web page?
Kenneth, GEOGRAF A/S ks at geograf.dk
Wed Jan 30 04:36:07 EST 2008
Yes, the mapviewerajax should be configured with the correct default page.
If you use the "mapviewerjava", you must add ajaxviewer.jsp page name.
The full url becomes:
/mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://mylayout.WebLayout&username=Anonymous&password=
Regards, Kenneth, GEOGRAF A/S
dorra2007 skrev:
>   Thank you Kenneth for the code segment;
> But there is no folder named mapviewerajax; so I have changed it to
> mapviewerjava. I have tried it and the result is the title (This is my
> webpage with an embedded map!)+ blank: the map isnot displayed (instead of
> the map lays a blank square.)
> Have you an idea about what the problem can be?
> Kenneth, GEOGRAF A/S wrote:
>> Yes, it is possible.
>> My favorite  method is to embed the Map in an Iframe:
>> <html>
>> <body>
>> <h1>This is my webpage with an embedded map!</h1>
>> <iframe
>> src="/mapguide/mapviewerajax/?weblayout=Library://mylayout.WebLayout&username=Anonymous&password="
>> width="100%" height="100%"></iframe>
>> </body>
>> </html>
>> By adding commands, do you mean from code?
>> What sort of commands do you want to add, and why is Studio not an option?
>> dorra2007 skrev:
>>> Hello all;
>>> I have one precise question: Is it possible to display the mapguide map
>>> in
>>> my own web page?
>>> If yes; what should I do? And how could I add commands without using
>>> mapguide studio?
>>> Thank you in advance.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080130/561cbff3/attachment.html
