[mapguide-users] How to embed the map in my own web page?
Kenneth, GEOGRAF A/S ks at geograf.dk
Wed Jan 30 07:13:15 EST 2008
You can only display WebLayouts with the viewer.
You must also enter the full path to the weblayout:
Library://mylayout.WebLayout
Regards, Kenneth, GEOGRAF A/S
dorra2007 skrev:
> i have an error message: Invalid repository type.
> Whereas the map is displayed in mapguide studio.
> NB: I use postgis as data source.
> Kenneth, GEOGRAF A/S wrote:
>> Yes, the mapviewerajax should be configured with the correct default page.
>> If you use the "mapviewerjava", you must add ajaxviewer.jsp page name.
>> The full url becomes:
>> /mapguide/mapviewerjava/ajaxviewer.jsp?weblayout=Library://mylayout.WebLayout&username=Anonymous&password=
>> dorra2007 skrev:
>>>   Thank you Kenneth for the code segment;
>>> But there is no folder named mapviewerajax; so I have changed it to
>>> mapviewerjava. I have tried it and the result is the title (This is my
>>> webpage with an embedded map!)+ blank: the map isnot displayed (instead
>>> of
>>> the map lays a blank square.)
>>> Have you an idea about what the problem can be?
>>>> Yes, it is possible.
>>>> My favorite  method is to embed the Map in an Iframe:
>>>> <html>
>>>> <body>
>>>> <h1>This is my webpage with an embedded map!</h1>
>>>> <iframe
>>>> src="/mapguide/mapviewerajax/?weblayout=Library://mylayout.WebLayout&username=Anonymous&password="
>>>> width="100%" height="100%"></iframe>
>>>> </body>
>>>> </html>
>>>> By adding commands, do you mean from code?
>>>> What sort of commands do you want to add, and why is Studio not an
>>>> option?
>>>> dorra2007 skrev:
>>>>> Hello all;
>>>>> I have one precise question: Is it possible to display the mapguide map
>>>>> in
>>>>> my own web page?
>>>>> If yes; what should I do? And how could I add commands without using
>>>>> mapguide studio?
>>>>> Thank you in advance.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080130/a3df11ea/attachment.html
