[mapguide-users] Oracle Max 10 Connections
Pascal Coulon pascal.coulon at atkinsglobal.com
Wed Jan 30 09:11:37 EST 2008
Hi there,
I am using Windows Server 2003 stantard edition. I do not think I am limited
to 10 connections. Don't I? Any idea, how I can determine the maximum number
of connections?
Regards,
zspitzer wrote:
> out of interest what platform are you running on? XP has the stupid limit
> of
> 10 tcp connections
> http://www.lvllord.de/ has a patcher which increases this limit
> On Jan 30, 2008 11:01 PM, Pascal Coulon <pascal.coulon at atkinsglobal.com>
> wrote:
>> Thank you very much for your reply. I have increased the number of
>> connections for autodesk.oracle to higher level. Unfortunatelly, whatever
>> the number of users (e.g. 60 users), I only got a maximum of 11
>> conenctions.
>> We are confident that oracle is properly set-up with a maximum amount of
>> session of 100. While executing the test, I had a total of 36 sessions.
>> Do you have reference on the maximum number of conenctions available in
>> the
>> pool? Is there a maximum connection value which overides the
>> configuration
>> parameters?
>> Regards,
>> Pascal
>> Bruce Dechant wrote:
>> > The connection limit for specific providers is specified in the
>> > serverconfig.ini file.
>> > Please check this setting:
>> > DataConnectionPoolSizeCustom
>> > Example of the above:
>> > DataConnectionPoolSizeCustom = Autodesk.Oracle:10
>> > If the above setting is not limiting the # of Oracle connections then
>> the
>> > connection limit is controlled at the Oracle DB side.
>> > Note: Changing the setting in the serverconfig.ini file DOES NOT
>> override
>> > what was set by the Oracle DBA. The setting in Oracle itself is what
>> > ultimately limits the # of concurrent connections.
>> > Thanks,
>> > Bruce
>> > -----Original Message-----
>> > From: mapguide-users-bounces at lists.osgeo.org
>> > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Pascal
>> Coulon
>> > Sent: Tuesday, January 29, 2008 1:01 PM
>> > To: mapguide-users at lists.osgeo.org
>> > Subject: [mapguide-users] Oracle Max 10 Connections
>> > Hi There,
>> > We have a system based on MapGuide Enterprise, the Autodesk.Oracle
>> > provider
>> > and an Oracle 10G R2. I have built a load test using Visual Studio
>> 2008.
>> > Every 5 seconds 60 new simultaneous users request a map.
>> > I noticed that whatever the number of users, I still have a maximum of
>> 10
>> > active connections to the Oracle Instance. I believe that MapGuide must
>> > have
>> > a pool of connections to Oracle; which are recycled regularly. The
>> issue
>> > is
>> > that if the number of users increases dramatically, the all system will
>> be
>> > badly slow. Can somebody advise on the maximum numbers of connection we
>> > can
>> > hope with the Autodesk.Oracle provider. Can somebody also advise on a
>> > possible tuning?
>> > Any help would be appreciated.
>> > regards,
>> > Pascal
>> > View this message in context:
>> http://www.nabble.com/Oracle-Max-10-Connections-tp15169231s16610p15169231.html
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> http://www.nabble.com/Oracle-Max-10-Connections-tp15169231s16610p15180738.html
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/Oracle-Max-10-Connections-tp15169231s16610p15182894.html
