[mapguide-users] New User Help (.net)
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Jan 31 09:31:25 EST 2008
Usually this happens because the preview shows the wrong part of the map
(where there is no data).
Try creating a map, and set the map extents to match your data.
Regards, Kenneth, GEOGRAF A/S
cgrell skrev:
> Thank you for the reply.
> In the end I was putting the sample in the wrong location which ment it was
> calling the mapviewerajax from the wrong location.
> Now I am working with a demo MapGuide Studio and trying to get a simple .shp
> file loaded.
> The data and layer were loaded fine. The layer's preview shows what I was
> expecting.
> I have tried to create a map based on the layer and the map preview shows
> nothing.
> Does anyone have some tips that could help me with this?
> Thank you
> Kenneth, GEOGRAF A/S wrote:
>> As I recall, you must also install a demo website (the MGP package only
>> has the data for the demo).
>> I believe the correct package is named "DotNetViewerSample".
>> You might get away with running this:
>> http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f%2fSamples%2fSheboygan%2fLayouts%2fSheboyganAsp.WebLayout&USERNAME=Anonymous&PASSWORD=
>> You will also need an editor for the data.
>> You can request a trial of MapGuide Studio from Autodesk, and they will
>> send a 30 (60?) day trial CD by mail.
>> cgrell skrev:
>>> I have been struggling with this for weeks now and am very stuck.
>>> I have installed the MapGuide Server 1.2.0, Web Server Extenstions 1.2.0
>>> using .net
>>> I can login to the admin at http://localhost/mapguide/mapadmin/login.php
>>> and
>>> loaded the sample file Sheboygan.mgp
>>> When I go to http://localhost/mapguide/mapviewernet/gettingstarted.aspx I
>>> get the following error
>>> Invalid repository type. Exception occurred in method
>>> MgResourceIdentifier.ParseIdentifier at line 440 in file
>>> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\common\platformbase\Services/ResourceIdentifier.cpp
>>> When i go to http://localhost/mapguide/mapviewernet/ajaxviewer.aspx i get
>>> the following error
>>> An unclassified exception occurred.
>>> An unclassified exception occurred. Exception occurred in method
>>> new_MgResourceIdentifier at line 681 in file .\MgApi_wrap.cpp
>>> What am I missing?
>>> Thank you
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080131/887f25fb/attachment.html
