[mapguide-users] Mapguide 1.2.0 "make" error (recompile with
	-fPIC)
    Zac Spitzer
    zac.spitzer at gmail.com
    Thu Jul  3 05:21:59 EDT 2008
i think your problem is your on 64-bit and i don't think it's
supported yet, there has been some tasks
in trac about adding 64-bit support recently but for now i would
recommend going 32-bit,
I went down the same path with 64 bit on CentOS and only got things
working once i switched back to 32 bit
any reason why your using 1.2 and not 2.0?
On Thu, Jul 3, 2008 at 7:09 PM, Muhammad Mubashar Shoaib
<mubasharbhai at gmail.com> wrote:
> Hi everyone,
> I have been struggling with mapguide server installation on my Cent OS 4.5
> box for a while now. I followed the instructions as found on
> http://mapguide.osgeo.org/1.2/docs/BuildConfigureMgOpenSourceOnLinux/Index.html
> I issued the configure command as follows:
> $# ./configure --enable-optimized --with-pic --with-fdo-include=/usr/local
> /fdo-3.2.2/include/ --with-fdo-lib=/usr/local/fdo-3.2.2/lib/
> $# make
> The make command ended up spitting out the following error:
> *** Warning: Linking the shared library libMgGeometry.la against the
> *** static library ./../Oem/geos-2.2.0/source/geom/.libs/libgeos.a is not
> portable!
> g++ -shared -nostdlib
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../lib64/crti.o
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/crtbeginS.o  libs/GeometryBuild.o
> -Wl,--rpath
> -Wl,/home/apnakara/zips/mapguide/mapguide-1.2.0/Common/CoordinateSystem/.libs
> -Wl,--rpath
> -Wl,/home/apnakara/zips/mapguide/mapguide-1.2.0/Common/Foundation/.libs
> -Wl,--rpath -Wl,/usr/local/mapguideopensource/lib
> -L/home/apnakara/zips/mapguide/mapguide-1.2.0/Common/MdfModel/.libs
> -L/home/apnakara/zips/mapguide/mapguide-1.2.0/Common/MdfParser/.libs
> -L/home/apnakara/zips/mapguide/mapguide-1.2.0/Oem/dbxml-2.2.13/install/lib
> -L/home/apnakara/zips/mapguide/mapguide-1.2.0/Oem/proj-4.5.0/src/.libs
> -L/usr/kerberos/lib64 -L/usr/kerberos/lib -L/usr/lib64
> -L/home/apnakara/zips/mapguide/mapguide-1.2.0/Oem/gdal-1.4.0/.libs
> -L/home/apnakara/zips/mapguide/mapguide-1.2.0/Oem/ACE/ACE_wrappers/ace
> -L/home/apnakara/zips/mapguide/mapguide-1.2.0/Common/Foundation
> -L/home/apnakara/zips/mapguide/mapguide-1.2.0/Common/CoordinateSystem -lACE
> /home/apnakara/zips/mapguide/mapguide-1.2.0/Common/CoordinateSystem/.libs/libMgCoordinateSystem.so
> /home/apnakara/zips/mapguide/mapguide-1.2.0/Common/Foundation/.libs/libMgFoundation.so
> ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a
> -L/usr/lib/gcc/x86_64-redhat-linux/3.4.6
> -L/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../lib64
> -L/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../.. -L/lib/../lib64
> -L/usr/lib/../lib64 -lstdc++ -lm -lc -lgcc_s
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/crtendS.o
> /usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../lib64/crtn.o  -Wl,-soname
> -Wl,libMgGeometry.so.7 -o .libs/libMgGeometry.so.7.0.0
> /usr/bin/ld:
> ./../Oem/geos-2.2.0/source/geom/.libs/libgeos.a(GeometryFactory.o):
> relocation R_X86_64_32S against `vtable for geos::GeometryFactory' can not
> be used when making a shared object; recompile with -fPIC
> ./../Oem/geos-2.2.0/source/geom/.libs/libgeos.a: could not read symbols: Bad
> value
> collect2: ld returned 1 exit status
> make[2]: *** [libMgGeometry.la] Error 1
> make[2]: Leaving directory
> `/home/apnakara/zips/mapguide/mapguide-1.2.0/Common/Geometry'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/home/apnakara/zips/mapguide/mapguide-1.2.0/Common'
> make: *** [all-recursive] Error 1
> It appears as if it is suggesting the use of -fPIC flag, although as you may
> notice in the configure command above, I have used the --with-pic flag (I
> assume that this should be covered due to the use of this flag).
> Other details:
> $# uname -a
> Linux xxx.xxx.com 2.6.9-67.0.4.ELsmp #1 SMP Sun Feb 3 07:06:14 EST 2008
> x86_64 x86_64 x86_64 GNU/Linux
> $# gcc -dumpversion
> 3.4.6
> I am all ears for your suggestions.
> Regards,
> Muhammad Mubashar Shoaib.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
