[mapguide-users] Create a Visual Studio 2008 Solution of dotnetviewersample
Jackie C. Ng jumpinjackie at gmail.com
Thu Jul 3 10:59:39 EDT 2008
Sorry if you are using .net you *HAVE* to use IIS. There are two parts
involved with communication to the mapguide server:
1 - The .net server-side API (for your custom scripts)
2 - The mapagent http endpoint (for the AJAX viewer and MapGuide
Studio/Maestro)
The Visual Studio built-in webserver does not support (2) and WILL NOT WORK.
IIS supports both.
About the dotnetviewersample:
It is assumed to lie under the "www" directory of your MapGuide
installation.
Eg C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample
Also IMO it is not the ideal reference application as it is done in the
style of classic asp (inline code, includes, lots of un-.net stuff) making
it really confusing to asp.net developers used to code-behind and stuff like
that.
Hope that helps.
- Jackie
stoff wrote:
> Hi,
> I downloaded the dotnetviewersample and want o make a Visual Studio 2008
> project of it. After copying the sample code to the VS-www directory and
> the MG-dlls to the bin directory, I opend the directory as Website. Trying
> to compile,  I came across the following problems ...
> 1) Type or Namespace JsonObject was not found => I took the proper
> namespace Jayrock.Json ... works!
> 2) File \query\property.aspx could not be found => not strange, because it
> is stored in the directory \query\classes\property.aspx ... but where is
> this path stored?... in a binary?  I have not found it in the code and
> moved the file in the directory above ... dirty but works ...
> 3) The path /utilityfunctions.aspx could not be assigned. ... found some
> wrong include paths, but can't eleminate this error ... any ideas?
> A downloadable Visual Studio website solution would be great ...  ;-)
> Has anyone experiences with the asp.net development server? I don't want
> to install IIS on my development machine ...
> Best regards ...
> stoff
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/Create-a-Visual-Studio-2008-Solution-of-dotnetviewersample-tp18235849p18260186.html
