[mapguide-users] Postgis Selection Problem
Gabriele Monfardini gabrimonfa at gmail.com
Fri Jul 4 12:08:01 EDT 2008
I don't know if this may apply to you since I've the old 1.2 version
of MapguideOS.
I solved the same problem reading http://www.gdal.org/ogr/drv_pg.html
and adding a field ogc_fid with unique property.
A restart of the server and then the blue polygons started to appear.
Let us know if you solve the problem
Gabriele
On Fri, Jul 4, 2008 at 15:06, gimbrogno <magnitudo9 at email.it> wrote:
> Hi I have the same problem with MGOS 2.0.1 and FDO 3.3.1... Have you solved?
> Can you tell me how can I solve this problem?
> Thanks in advance...
> ary sucaya wrote:
>> Hello group,
>> I did install MGOS 2.0RC3 with postgis fdo provider. I found something
>> wrong with select feature tool. It bring up selected information on
>> property panel but not show me selected object (with blue color) on the
>> map. On the other hand, i could see selected object on the map if i did
>> selection programatically from task pane.
>> Anyone can tell me weather this is mapguide problem or fdo problem?
>> Thx,
>> Ary Sucaya
>> ____________________________________________________________________________________
>> Never miss a thing.  Make Yahoo your home page.
>> http://www.yahoo.com/r/hs
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Postgis-Selection-Problem-tp15465041p18279138.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
