[mapguide-users] Error building Linux MGOS 2.0
Zac Spitzer zac.spitzer at gmail.com
Sat Jul 5 01:39:20 EDT 2008
anything in this thread help?
http://www.nabble.com/Error-in-compiling-Agg-on-ubuntu...-td13600729.html
On Sat, Jul 5, 2008 at 3:30 PM, Dorin <did_1414 at yahoo.com> wrote:
> Hi,
> It didn't work. I had the same error:
> /usr/src/mapguide-2.0.1/Common/Renderers/.libs/libMgRenderers.so:
> undefined reference to `gdFontCacheShutdown'
>  undefined reference to `gdFontCacheSetup'
>  collect2: ld returned 1 exit status
>  make[3]: *** [mgserver] Error 1
> I think the errors are from the 2 unresolved reference, from the gd library,
> but I don't know how I solved this.
> Any ideea?
> best regards
> ----- Original Message ----
> From: gimbrogno <magnitudo9 at email.it>
> To: mapguide-users at lists.osgeo.org
> Sent: Friday, July 4, 2008 2:03:35 PM
> Subject: Re: [mapguide-users] Error building Linux MGOS 2.0
> Hi I had succes with the same configuration...
> Try these steps:
> Needed Packages:
> yum grouplist
> yum groupinstall mysql
> yum install unixODBC unixODBC-devel libjpeg-devel mysql-server
> chkconfig mysqld on
> service mysqld start
> Building and Installing Required Components (installer)
> tar zxf mapguideaptinstaller-*.tar.gz
> cd LinuxApt
> ./build_apt.sh --port 80
> Building and Installing FDO
> find . -maxdepth 1 -name "fdo*.tar.gz" -exec tar zxf {} ";"
> cd OpenSource_FDO
> nano -w setenvironment.sh
> source ./setenvironment.sh
> ./build_thirdparty.sh
> ./build_linux.sh
> Building OEM Components in the MapGuide Distribution
> tar zxf mapguide-*.tar.gz
> cd mapguide-
> ./build_oem.sh
> Building and Installing the Default Configuration
> aclocal
> libtoolize --copy --force
> automake --add-missing --copy
> autoconf
> ./configure --enable-optimized
> make
> make install
> Tell me if it goes...
> Dorin333 wrote:
>> Hi,
>> CentOS 5, gcc 4.1.2.14 versionI tried with Suse 10 and I have the same
>> problem.
>> Sent: Friday, July 4, 2008 10:08:13 AM
>> Hi, what linux disto are you using and especially what gcc version?
>> Dorin333 wrote:
>>> Hi all,
>>> I have the following error message for mapguide-2.0.1:
>>> warning: libxerces-c.so.27,
>>> needed by
>>> /usr/src/mapguide-2.0.1/Server/src/Services/Drawing/.libs/libMgServerDrawingService.so,
>>> may conflict with libxerces-c.so.25
>>> I installed the fdo 3.3.1 that is based on  libxerces-c.so.25.
>>> Can everyone tell me how I solve this issue.
>>> Thanks a lot.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/Error-building-Linux-MGOS-2.0-tp18273122p18274880.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://www.nabble.com/Error-building-Linux-MGOS-2.0-tp18273122p18277375.html
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
