[mapguide-users] Error building Linux MGOS 2.0
Dorin did_1414 at yahoo.com
Mon Jul 7 04:25:15 EDT 2008
No. It  didn't work. I aaaaalso tried to update de gd and gd-devel library, but the errors remain.
Any other   suggestions?
Thanks, Dorin
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Sunday, July 6, 2008 11:34:04 AM
Subject: Re: [mapguide-users] Error building Linux MGOS 2.0
Ehm, it seems that the linker cannot link the library to the static object,
and now you might try to kid the compiler...
ldd /usr/local/fdo-3.3.0/lib/libFDO-3.3.0.so and you can see that there are
2 missing deps:
- libxalanMsg.so.17
- libxerces-c.so.25
and then copy
/your_path/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/lib/libxalanMsg.so.17
to /usr/lib
and
/your_path/OpenSource_FDO/Thirdparty/apache/xml-xalan/c/lib/libxerces-c.so.25
to /usr/lib
So the compiler can links the two libraries to the static object...
Try and tell me if it goes  =)
Dorin333 wrote:
> Hi all,
> I have the following error message for mapguide-2.0.1:
> warning: libxerces-c.so.27,
> needed by
> /usr/src/mapguide-2.0.1/Server/src/Services/Drawing/.libs/libMgServerDrawingService.so,
> may conflict with libxerces-c.so.25
> /usr/src/mapguide-2.0.1/Common/Renderers/.libs/libMgRenderers.so:
> undefined reference to `gdFontCacheShutdown'
> undefined reference to `gdFontCacheSetup'
> collect2: ld returned 1 exit status
> make[3]: *** [mgserver] Error 1
> I installed the fdo 3.3.1 that is based on  libxerces-c.so.25.
> Can everyone tell me how I solve this issue.
> Thanks a lot.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Error-building-Linux-MGOS-2.0-tp18273122p18299924.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080707/1cbdcc80/attachment.html
