[mapguide-users] Best Db/FDO connection with MGOS 2.0.1 ?
Dorin did_1414 at yahoo.com
Mon Jul 7 08:09:53 EDT 2008
Lucky you, I tried to install on Linux, as you known, and I didn't succeded till now.
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Monday, July 7, 2008 3:01:30 PM
Subject: Re: [mapguide-users] Best Db/FDO connection with MGOS 2.0.1 ?
Hi Dorin333, thanks a lot for your support... I forgot an important think,
that I run mapguideopensource under a linux system.
Dorin333 wrote:
> Try this solution with MsSqlSpatial ( open source also). I tested on
> Windows version and it works.
> More information here:  http://www.sl-king.com/FdoMsSql/FdoMsSql.html
> From: gimbrogno <magnitudo9 at email.it>
> Sent: Monday, July 7, 2008 12:50:34 PM
> Subject: [mapguide-users] Best Db/FDO connection with MGOS 2.0.1 ?
> Hi all ,
> I am trying to connect Mapguide Open Source via FDO provider with a
> postgresql+postgis without success!
> It was the best solution for me, but unfortunatelly I am not able to make
> this connection to work, so I ask you what is the best way to connect
> Mapguide with a db to draw some points of interest stored in two kinds of
> tables for two different type of geometry in the same database.
> I would not to use Oracle, but I accept any advice...
> Thanks a lot in advance
> http://www.nabble.com/Best-Db-FDO-connection-with-MGOS-2.0.1---tp18314087p18314087.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Best-Db-FDO-connection-with-MGOS-2.0.1---tp18314087p18315131.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080707/67bb527e/attachment.html
