[mapguide-users] MAESTRO AND POINT STYLE
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jul 7 16:01:26 EDT 2008
Unfortunately Maestro does not yet support non-built-in symbols.
You can enter a ticket, requesting that is is supported:
http://trac.osgeo.org/mapguide/newticket
(You must be logged in with an OSGeo ID)
Regards, Kenneth Skovhede, GEOGRAF A/S
Jamo181 skrev:
> Hi I was wondering if I should be getting an error when clicking in the point
> style then clicking symbol... it errors out with an unhandled exception Blah
> Blah
> ************** Exception Text **************
> System.ArgumentException: Must specify valid information for parsing in the
> string.
>    at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
>    at
> OSGeo.MapGuide.Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.Symbol_SelectedIndexChanged(Object
> sender, EventArgs e)
>    at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
>    at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
>    at System.Windows.Forms.ComboBox.WndProc(Message& m)
>    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
>    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
>    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
> IntPtr wparam, IntPtr lparam)
> this also happens when I click Font and I also get an error when trying to
> add a symbol definition, however I can add a symbol library definition
> without any errors....
> But I don't know how to make my points pick up my symbol from the library
> definition....?
> Is this meant to be happening or am I missing something from my install?
> Standard points work fine but I am required to add custom points such as
> water meters, manholes, signage, etc etc....
