[mapguide-users] radio button instead of check box in legend. Is it possible?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jul 8 02:15:44 EDT 2008
That depends on how much work you are willing to do.
There is no support for this in the viewer, so you have to do it yourself.
The places to fix are the files legend*.templ and legend*.aspx/php/jsp.
In any case, it is likely to be very messy, depending on some special
group name or other non-obvious setup. You will also have trouble
upgrading if you change the viewer files.
Instead, I suggest you add an extra frame somewhere, and keep the
radio buttons there, and the layers invisible in the legend.
Regards, Kenneth Skovhede, GEOGRAF A/S
Dumas A skrev:
> Hi,
> Is it possible to have radio button instead of check box in map
> legend? The idea is to have folder in legend where different image
> mosaics are, User can choose what background info he needs.  We want
> to have similar functionality of our data like google maps have on top
> rigth corner of map.
> Regards,
> Danas
> By the way, How MGOS works with raster data if it overlaps? Does it
> read only top layers or it reads all raster datasets before drawing
> image?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080708/da0a7282/attachment.html
