[mapguide-users] Expression building with Property extensions... in maestro if possible
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jul 8 03:42:09 EDT 2008
I have had only limited success with the calculated properties.
I cannot get a calculated property to work as a tooltip on an
OGR feature source, but it can show up in the selection info.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jamo181 skrev:
> Hi I've done a little searching around and found this to have already been
> fixed in this ticket...
> http://trac.osgeo.org/mapguide/ticket/282
> http://trac.osgeo.org/mapguide/ticket/284
> Fixed Describe schema to include the calculated properties from the
> extension.
> What I was hoping is that someone could tell me the syntax to create a new
> calculated property with a some joined data. I'm using Maestro if this
> helps....
> Current String is
> Concat(Concat(Concat(' ,Ext1somesite),' ),Ext1somesitedesc),' ')
> Help ?
