[mapguide-users] Raster images in MGE 2009
Dave Brett dbrett at digitalglobe.com
Tue Jul 8 12:07:39 EDT 2008
Trevor -
  two questions,
  1. The second arg for the Get/SetResourceData(MgResourdeIdentifier, string
dataName) methods, where does this value come from or what should this be?
when I execute the method I receive a "Resource data was not found:
<dataName>".  The exception is the same regardless of what the dataName arg
value is.  Obviously I am missing something here.
  2. I can not find a config.xml anywhere on the file system. Before
clicking "Test Connection" and Save, or After testing the connection and
saving.  Any suggestions?
thanks,
dave
The MGE 2009 raster provider looks at the config.xml document stored with
the raster feature source to determine which raster files to load.  This
document can be accessed using Get/SetResourceData.  Autodesk MapGuide
Studio regenerates this document when you hit "Test Connection" on the
feature source and then save it.
MGE 2009 does not update the config.xml document so any changes to the
imagery will not be reflected automatically.
Thanks,
Trevor
-----Original Message-----
From: Zac Spitzer [mailto:zac.spitzer at gmail.com]
Sent: Monday, July 07, 2008 7:56 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Raster images in MGE 2009
On Mon, Jul 7, 2008 at 11:23 PM, Dave Brett <dbrett at digitalglobe.com> wrote:
> Zac -
>  i am not sure I exactly understand your suggestion. I looked into the
> FeatureService and the ResourceService and the closest things I can find
> to
> what you are describing is using the
> ResourceService.GetResourceData/SetResourceData methods.
yep, that's what you need to do
View this message in context: http://www.nabble.com/Raster-images-in-MGE-2009-tp18304693p18342812.html
