[mapguide-users] Problems connecting to database: No current open database.
lolob azzam_wahab at hotmail.com
Thu Jul 10 00:50:32 EDT 2008
I changed to upper..but with no luck..is it because of MGOS 1.2 itself?
zspitzer wrote:
> Try using upper case, oracle is case sensitive which means it can't
> find any tables because
> the FDO ODBC will look in the system tables for owner='username' when
> it should be owner='USERNAME'
> as all system tables are in upper case in oracle
> z
> On Thu, Jul 10, 2008 at 1:35 PM, lolob <azzam_wahab at hotmail.com> wrote:
>> No, both username and password are lower case..anyone??
>> zspitzer wrote:
>>> did you have your username in upper case?
>>> On Thu, Jul 10, 2008 at 11:53 AM, lolob <azzam_wahab at hotmail.com> wrote:
>>>> Hello list,
>>>> I'm having some trouble connecting to Oracle here. I have Oracle9i
>>>> database,MGOS 1.2 and MG Studio 2008.
>>>> I created a system DSN (via ODBC) on Windows Server 2003 to the oracle
>>>> database. Hit the test button and success. Now I know my machine can
>>>> connect
>>>> to the oracle database(other machine) via ODBC. I open the MG Studio
>>>> 2008,
>>>> use the data connection via a Data Source Name (DSN), hit the test
>>>> connection and got this "An exception occurred in FDO component.RDBMS:
>>>> No
>>>> current open database" The oracle client and the odbc driver is 10g.
>>>> Help
>>>> please...
>>>> View this message in context:
>>>> http://www.nabble.com/Problems-connecting-to-database%3A-No-current-open-database.-tp18112121p18374419.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> Zac Spitzer -
>>> http://zacster.blogspot.com (My Blog)
>>> +61 405 847 168
>> http://www.nabble.com/Problems-connecting-to-database%3A-No-current-open-database.-tp18112121p18375230.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/Problems-connecting-to-database%3A-No-current-open-database.-tp18112121p18375864.html
