[mapguide-users] Get Coordinates
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jul 10 03:16:15 EDT 2008
It's a bit unclear what you want.
If you want to get the coordinate when you click, Dorin is correct.
The javascript function is called "DigitizePoint".
If you want to display the coordinates as the mouse moves, you will have to
study the file "ajaxmappane.templ" and figure out what function to hook
into.
Regards, Kenneth Skovhede, GEOGRAF A/S
Dorin skrev:
> Hi,
> On the phpviewer sample (PHP code) you have a markup option, and you
> can create on a click mouse on a map (get coordinate x,y) an point.You
> can studying this samples in order to find a solution.
> Dorin
> ----- Original Message ----
> From: gimbrogno <magnitudo9 at email.it>
> To: mapguide-users at lists.osgeo.org
> Sent: Tuesday, July 8, 2008 6:28:46 PM
> Subject: Re: [mapguide-users] Get Coordinates
> Hi I have the same problem... Have you solved? Can you or any other people
> help me to solve my problem?
> Thanks a lot
> Jhonn Jairo Vesga Cadena wrote:
> > Hi, i have a map in autodesk studio 2007, and i need to solve this
> issue:
> > I need to create a point begins by click on the map, when i click the
> > application launch a window where i get the X and Y coordinate, the
> > problem its that, how can i get that coordinate??
> > Some ideas??
> > Thanks
> > att:
> > Móvil:
> > Movistar: 316-524-4147
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Get-Coordinates-tp13951030p18341934.html
> Sent from the MapGuide Users mailing list archive at Nabble.com
> <http://Nabble.com>.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080710/fd26361e/attachment.html
