[mapguide-users] MG Studio 2009 - MGOS 2.0.1 - FdoKingOracle - Connection Box Problem
Rahul unicorn_admirer at yahoo.com
Thu Jul 10 05:12:07 EDT 2008
Hi ,
I tested with two Different machine ,One Machine having Windows XP+MGOS1.2.0 and then i connected to the mapguide site using the MapGuide Studio2008 installed on different windows xp machine but within the same network and it works well.
Now in the second case i have Windows Server 2003+MGOS2.0.1 and then i connected to the mapguide site using MapGuide Studio 2008 as well as 2009 installed on another machine but on the same network and i unable to get the connectino property details in the box hence unable to use the connection parameters.I hope this will give you a fair bit of idea about the exact situation.
Max !
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Thursday, July 10, 2008 3:34:05 PM
Subject: Re: [mapguide-users] MG Studio 2009 - MGOS 2.0.1 - FdoKingOracle - no geometry is rendered
Do you have Oracle client installed on Windows XP machine?
Simon
Rahul wrote:
    Intresting ,How you able to view the Connection Properties Boxes, As I am using Windows Server 2003 with MGOS 2.0.1 and then on another machine Windows XP having MapGuide Studio 2009,I downloaded FdoKingOracle_Win32_FDO_3_3_v0_7_4 as well as necessary files for the oracle Instant Client in the \Server\Bin\FDO Folder.
Once I connect to the MapGuide Studio and try to open connection i use to see the configuration setting for King Oracle FDO Provider but have nothing in the connection string, so i unable to enter the Property and the corresponding values.It use to work well on my machine having MGOS1.2.0 Windows XP with MGS 2008.
Thks
Max !!
To: mapguide-users at lists.osgeo.org
Sent: Wednesday, July 9, 2008 7:43:08 PM
Subject: [mapguide-users] MG Studio 2009 - MGOS 2.0.1 - FdoKingOracle - no geometry is rendered
Howdy,
Windows XP
MGOS 2.0.1
MG Studio 2009 with FdoKingOracle_Win32_FDO_3_3_v0_7_4
Entry from providers.xml:
            <FeatureProvider>
            <Name>King.Oracle.0.1.1</Name>
            <DisplayName>King Provider for Oracle</DisplayName>
            <Description>Read/write access to spatial and attribute data in
an Oracle Spatial.</Description>
            <IsManaged>False</IsManaged>
            <Version>0.1.1.0</Version>
            <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
            <LibraryPath>C:\Program
Files\MapGuideOpenSource2.0\Server\Bin\FDO\KingOracleProvider.dll</LibraryPath>
            </FeatureProvider>
Oracle instantclient_10.2 on the box.
No issues with connection. All seems to work well in terms of collecting the
schema and attribute information.
When creating a Layer … Layer Preview never seems to render any geometry …
This error:
<2008-07-08T16:20:19>    Fusion Viewer            Administrator
Error: Failed to stylize layer: test_KOP
        The coordinate system is invalid.
        Could not create coordinate system forward transformation with
specified coordinate systems.
StackTrace:
  - MgMappingUtil.StylizeLayers line 775 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\mapping\MappingUtil.cpp
Could not create coordinate system forward transformation with specified
coordinate systems.
I am using SRID = 2236.
select srid, cs_name, auth_srid from MDSYS.CS_SRS where srid = 2236;
2236    NAD83 / Florida East (ftUS)        2236
… Now today ….
When attempting to create new layer using the above provider I get this:
An exception occurred in FDO component. ORA-32102: invalid OCI handle
Seems pretty “flacky” to me because when I “Configure a Feature Resource
using Generic Editor “
Connection test is successful AND when I do the “Preview -> Refresh” it
pulls down all of my classes (appox. 20 in this case)
“View Data” works .. great!!
“View Feature” retrieves the correct feature count.
… however nothing renders!!! Just spins …
Anyone aware of any fix for any of this?
dennis
View this message in context: http://www.nabble.com/MG-Studio-2009---MGOS-2.0.1---FdoKingOracle---no-geometry-is-rendered-tp18360497p18360497.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.138 / Virus Database: 270.4.7/1543 - Release Date: 9.7.2008 18:32
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080710/bea68ce9/attachment.html
