[mapguide-users] Get Coordinates
gimbrogno magnitudo9 at email.it
Fri Jul 11 07:04:49 EDT 2008
Hi I have another problem :(
The coordinate system that I can show on status bar are in meters (planar
Gauss-Boaga Roma40 (M. Mario)) and I would to show it in the standard WGS84
GD like google maps...
Can you help me? Thanks a lot...
Dorin333 wrote:
> Hi, tries this
> Longitude
> grade=(int)point.X/60
> minutes=(int) point.X/3600
> rests are seconds
> Latitude
> grades=(int)point.Y/60
> minutes=(int) point.Y/3600
> rests are seconds
> ----- Original Message ----
> From: gimbrogno <magnitudo9 at email.it>
> To: mapguide-users at lists.osgeo.org
> Sent: Thursday, July 10, 2008 12:33:58 PM
> Subject: Re: [mapguide-users] Get Coordinates
> Hi all, I have solved using the suggestions of Dorin333...
> I managed the DigitizePoint() function in the js, so when I click there is
> a
> popup with the coordinates (meters), but now I have to convert it into
> latlon. There is alredy a function that make this?
> Thanks a lot to all
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> It's a bit unclear what you want.
>> If you want to get the coordinate when you click, Dorin is correct.
>> The javascript function is called "DigitizePoint".
>> If you want to display the coordinates as the mouse moves, you will have
>> to
>> study the file "ajaxmappane.templ" and figure out what function to hook
>> into.
>> Regards, Kenneth Skovhede, GEOGRAF A/S
>> Dorin skrev:
>>> Hi,
>>> On the phpviewer sample (PHP code) you have a markup option, and you
>>> can create on a click mouse on a map (get coordinate x,y) an point.You
>>> can studying this samples in order to find a solution.
>>> Dorin
>>> Sent: Tuesday, July 8, 2008 6:28:46 PM
>>> Hi I have the same problem... Have you solved? Can you or any other
>>> people
>>> help me to solve my problem?
>>> Thanks a lot
>>> Jhonn Jairo Vesga Cadena wrote:
>>> > Hi, i have a map in autodesk studio 2007, and i need to solve this
>>> issue:
>>> > I need to create a point begins by click on the map, when i click the
>>> > application launch a window where i get the X and Y coordinate, the
>>> > problem its that, how can i get that coordinate??
>>> > Some ideas??
>>> > Thanks
>>> > att:
>>> > Móvil:
>>> > Movistar: 316-524-4147
>>> > _______________________________________________
>>> > mapguide-users mailing list
>>> > mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> View this message in context:
>>> http://www.nabble.com/Get-Coordinates-tp13951030p18341934.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com
>>> <http://Nabble.com>.
> http://www.nabble.com/Get-Coordinates-tp13951030p18379167.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/Get-Coordinates-tp13951030p18401412.html
