Re[mapguide-users] ndering to PNG8
Jason Birch Jason.Birch at nanaimo.ca
Fri Jul 11 13:32:15 EDT 2008
Hi Lucio,
How are you determining the bit depth of the images?  I have found that
the Windows file information dialog incorrectly identifies images as
32bit when they are actually 8bit.
If you open the image in a different program (like Photoshop) or test
the size of format=PNG vs FORMAT=PNG8 you should be able to confirm that
8bit rendering is actually working.
Keep in mind that this only works for tiled maps.  To get back 8bit
images for regular maps, you will need to update the appropriate
template.
Jason
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of LucioSoto
Sent: Friday, July 11, 2008 10:03
To: mapguide-users at lists.osgeo.org
Subject: Re[mapguide-users] ndering to PNG8
Hi, I need some help, I'm changing the ImageFormat = PNG8 in
serverconfig.ini, but I'm still getting 32bit PNG images, if I change
that
to JPG it works, but it seems it is not recognizing PNG8 format. I have
Mapguide 2.0.0.2308 over Windows.
Thanks a lot,
Lucio
View this message in context:
http://www.nabble.com/Rendering-to-PNG8-tp18408388p18408388.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
