[mapguide-users] Error to log on to MGOS 2.0.1 using MapGuide Maestro
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jul 14 03:11:26 EDT 2008
I suspect that some mappings failed during installation.
You might try
http://localhost/mapguide/
or
http://localhost/mapguide/mapagent/isapi_MapAgent.dll
(IIS only, I don't know what the Apache plugin is called...
mod_MapGuide.so ?)
Regards, Kenneth Skovhede, GEOGRAF A/S
Zac Spitzer skrev:
> what happens if you open the url in a browser?
> z
> On Mon, Jul 14, 2008 at 5:01 PM, Intengu Technologies
> <sindile.bidla at gmail.com> wrote:
>> That is the url I am using: http://localhost/mapguide/mapagent/mapagent.fcgi
>> and the getting the error message.
>> 2008/7/13 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk>:
>>> Have you tried using the full URL?
>>> It should work with the shorter form, though.
>>> Intengu Technologies skrev:
>>> I am getting the following error message: Failed to log on because: Failed
>>> to connect, please check network connection and login information. Extended
>>> error info: Failed to connect, perhaps session is expired? Extended error
>>> info: The remote server returned an error: (404) Not Found
>>> I am using MapGuide Maestro r3235.msi on MGOS 2.0.1 and MGOS Web Studio
>>> works fine.
>>> Sindile Bidla
>>> ________________________________
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Sindile Bidla
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080714/d07da42f/attachment.html
