[mapguide-users] Raster Config XML File
Gordon McKenzie gord.mckenzie at canam.com
Mon Jul 14 10:35:16 EDT 2008
I am looking for some help on creating a raster config XML file.  I want to
attach an ESRI .asc grid file to AutoCAD Map.  I have a config file for
raster that I pinched from an AutoCAD Map code sample but I have not been
able to modify it in such as way as seems to work.  I can attach the raster
programatically but it complains about the "band" tag in the XML.  As this
is not bitmap of any sort I guess I can see why but I can't seem  to find
enough documentation to show me what to do.
Does anyone have a sample config file for a raster grd or can you point me
to some documentation resources that explain the contents.  I have found
little bits and pieces but nothing complete enough to get the job done.  Any
help would be greatly appreciated.   I have included my XML in case it is
helpful in answering
Thanks
<?xml version="1.0" encoding="UTF-8" ?>
<file:///C:\Documents%20and%20Settings\mckgor01\Local%20Settings\Temp\tempSu
rface.xml##> - <fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:gml="http://www.opengis.net/gml"
xmlns:fdo="http://fdo.osgeo.org/schemas"
xmlns:fds="http://fdo.osgeo.org/schemas/fds">
rface.xml##> - <gml:DerivedCRS gml:id="Default">
rface.xml##> - <gml:metaDataProperty>
rface.xml##> - <gml:GenericMetaData>
  <fdo:XYTolerance>0.001000</fdo:XYTolerance>
  <fdo:ZTolerance>0.001000</fdo:ZTolerance>
  </gml:GenericMetaData>
  </gml:metaDataProperty>
  <gml:remarks>System generated default FDO Spatial Context</gml:remarks>
  <gml:srsName>Default</gml:srsName>
rface.xml##> - <gml:validArea>
rface.xml##> - <gml:boundingBox>
  <gml:pos>550000.000000 6500000.000000</gml:pos>
  <gml:pos>552000.000000 6502000.000000</gml:pos>
  </gml:boundingBox>
  </gml:validArea>
  <gml:baseCRS xlink:href="http://fdo.osgeo.org/crs#default_cartesian" />
  <gml:definedByConversion
xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
  <gml:derivedCRSType
codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
  <gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
  </gml:DerivedCRS>
rface.xml##> - <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://fdo.osgeo.org/schemas/feature/rasters"
xmlns:rasters="http://fdo.osgeo.org/schemas/feature/rasters"
elementFormDefault="qualified" attributeFormDefault="unqualified">
rface.xml##> - <xs:element name="tempSurface" type="rasters:tempSurfaceType"
abstract="false" substitutionGroup="gml:_Feature">
rface.xml##> - <xs:key name="tempSurfaceKey">
  <xs:selector xpath=".//tempSurface" />
  <xs:field xpath="Id" />
  </xs:key>
  </xs:element>
rface.xml##> - <xs:complexType name="tempSurfaceType" abstract="false"
fdo:hasGeometry="false">
rface.xml##> - <xs:complexContent>
rface.xml##> - <xs:extension base="gml:AbstractFeatureType">
rface.xml##> - <xs:sequence>
rface.xml##> - <xs:element name="Id">
rface.xml##> - <xs:annotation>
  <xs:documentation />
  </xs:annotation>
rface.xml##> - <xs:simpleType>
rface.xml##> - <xs:restriction base="xs:string">
  <xs:maxLength value="256" />
  </xs:restriction>
  </xs:simpleType>
  </xs:element>
rface.xml##> - <xs:element name="Image" type="fdo:RasterPropertyType"
fdo:defaultImageXSize="200" fdo:defaultImageYSize="200"
fdo:srsName="Default">
rface.xml##> - <xs:appinfo source="http://fdo.osgeo.org/schemas">
  <fdo:DefaultDataModel dataModelType="Unknown" dataType="Unknown"
organization="Row" bitsPerPixel="32" tileSizeX="128" tileSizeY="128" />
  </xs:appinfo>
  </xs:annotation>
  </xs:element>
  </xs:sequence>
  </xs:extension>
  </xs:complexContent>
  </xs:complexType>
  </xs:schema>
rface.xml##> - <SchemaMapping provider="Autodesk.Raster.3.2" name="rasters"
xmlns="http://www.autodesk.com/isd/fdo/RasterFileProvider">
rface.xml##> - <complexType name="tempSurfaceType">
rface.xml##> - <RasterDefinition name="rasters">
rface.xml##> - <Location name="">
rface.xml##> - <Feature name="tempSurface.asc">
rface.xml##> - <Band name="RGB" number="1">
  <Image name="tempSurface.asc" frame="1" />
  </Band>
  </Feature>
  </Location>
  </RasterDefinition>
  </complexType>
  </SchemaMapping>
  </fdo:DataStore>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080714/3425e746/attachment.html
