[mapguide-users] Raster Config XML File
Gordon McKenzie gord.mckenzie at canam.com
Mon Jul 14 16:24:33 EDT 2008
Thanks Dave.  Unfortunately this does not do the trick.  I know this is not
an AutoCAD map group but was hoping that there might be some sample raster
XML files for asc grid or some pointers to documentation that would explain
what these files need to contain for each type of data.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Brett
Sent: Monday, July 14, 2008 10:47 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Raster Config XML File
I took this from a raster config file for the GDAL provider, it looks very
similar to the Autodesk providers config information.  It appears there is a
section missing from your image node (see bold text), hope this helps.
dave
<SchemaMapping xmlns="http://fdogrfp.osgeo.org/schemas"
provider="OSGeo.Gdal.3.3" name="default">
<complexType name="defaultType">
 <complexType name="RasterTypeType">
 <RasterDefinition name="images">
 <Location name="C:\temp\">
 <Feature name="633510537879531250.jpg">
 <Band name="RGB" number="1">
 <Image frame="1" name="633510537879531250.jpg">
 <Bounds>
  <MinX>-10000000</MinX>
  <MinY>-10000000</MinY>
  <MaxX>10000000</MaxX>
  <MaxY>10000000</MaxY>
  </Bounds>
  </Image>
  </Band>
  </Feature>
  </Location>
  </RasterDefinition>
  </complexType>
  </complexType>
  </SchemaMapping>
gom wrote:
> I am looking for some help on creating a raster config XML file.  I want
> to
> attach an ESRI .asc grid file to AutoCAD Map.  I have a config file for
> raster that I pinched from an AutoCAD Map code sample but I have not been
> able to modify it in such as way as seems to work.  I can attach the
> raster
> programatically but it complains about the "band" tag in the XML.  As this
> is not bitmap of any sort I guess I can see why but I can't seem  to find
> enough documentation to show me what to do.
> Does anyone have a sample config file for a raster grd or can you point me
> to some documentation resources that explain the contents.  I have found
> little bits and pieces but nothing complete enough to get the job done.
> Any
> help would be greatly appreciated.   I have included my XML in case it is
> helpful in answering
> Thanks
> <?xml version="1.0" encoding="UTF-8" ?>
<file:///C:\Documents%20and%20Settings\mckgor01\Local%20Settings\Temp\tempSu
> rface.xml##> - <fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:fdo="http://fdo.osgeo.org/schemas"
> xmlns:fds="http://fdo.osgeo.org/schemas/fds">
> rface.xml##> - <gml:DerivedCRS gml:id="Default">
> rface.xml##> - <gml:metaDataProperty>
> rface.xml##> - <gml:GenericMetaData>
>   <fdo:XYTolerance>0.001000</fdo:XYTolerance>
>   <fdo:ZTolerance>0.001000</fdo:ZTolerance>
>   </gml:GenericMetaData>
>   </gml:metaDataProperty>
>   <gml:remarks>System generated default FDO Spatial Context</gml:remarks>
>   <gml:srsName>Default</gml:srsName>
> rface.xml##> - <gml:validArea>
> rface.xml##> - <gml:boundingBox>
>   <gml:pos>550000.000000 6500000.000000</gml:pos>
>   <gml:pos>552000.000000 6502000.000000</gml:pos>
>   </gml:boundingBox>
>   </gml:validArea>
>   <gml:baseCRS xlink:href="http://fdo.osgeo.org/crs#default_cartesian" />
>   <gml:definedByConversion
> xlink:href="http://fdo.osgeo.org/coord_conversions#identity" />
>   <gml:derivedCRSType
> codeSpace="http://fdo.osgeo.org/crs_types">geographic</gml:derivedCRSType>
>   <gml:usesCS xlink:href="http://fdo.osgeo.org/cs#default_cartesian" />
>   </gml:DerivedCRS>
> rface.xml##> - <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
> targetNamespace="http://fdo.osgeo.org/schemas/feature/rasters"
> xmlns:rasters="http://fdo.osgeo.org/schemas/feature/rasters"
> elementFormDefault="qualified" attributeFormDefault="unqualified">
> rface.xml##> - <xs:element name="tempSurface"
> type="rasters:tempSurfaceType"
> abstract="false" substitutionGroup="gml:_Feature">
> rface.xml##> - <xs:key name="tempSurfaceKey">
>   <xs:selector xpath=".//tempSurface" />
>   <xs:field xpath="Id" />
>   </xs:key>
>   </xs:element>
> rface.xml##> - <xs:complexType name="tempSurfaceType" abstract="false"
> fdo:hasGeometry="false">
> rface.xml##> - <xs:complexContent>
> rface.xml##> - <xs:extension base="gml:AbstractFeatureType">
> rface.xml##> - <xs:sequence>
> rface.xml##> - <xs:element name="Id">
> rface.xml##> - <xs:annotation>
>   <xs:documentation />
>   </xs:annotation>
> rface.xml##> - <xs:simpleType>
> rface.xml##> - <xs:restriction base="xs:string">
>   <xs:maxLength value="256" />
>   </xs:restriction>
>   </xs:simpleType>
>   </xs:element>
> rface.xml##> - <xs:element name="Image" type="fdo:RasterPropertyType"
> fdo:defaultImageXSize="200" fdo:defaultImageYSize="200"
> fdo:srsName="Default">
> rface.xml##> - <xs:appinfo source="http://fdo.osgeo.org/schemas">
>   <fdo:DefaultDataModel dataModelType="Unknown" dataType="Unknown"
> organization="Row" bitsPerPixel="32" tileSizeX="128" tileSizeY="128" />
>   </xs:appinfo>
>   </xs:annotation>
>   </xs:element>
>   </xs:sequence>
>   </xs:extension>
>   </xs:complexContent>
>   </xs:complexType>
>   </xs:schema>
> rface.xml##> - <SchemaMapping provider="Autodesk.Raster.3.2"
> name="rasters"
> xmlns="http://www.autodesk.com/isd/fdo/RasterFileProvider">
> rface.xml##> - <complexType name="tempSurfaceType">
> rface.xml##> - <RasterDefinition name="rasters">
> rface.xml##> - <Location name="">
> rface.xml##> - <Feature name="tempSurface.asc">
> rface.xml##> - <Band name="RGB" number="1">
>   <Image name="tempSurface.asc" frame="1" />
>   </Band>
>   </Feature>
>   </Location>
>   </RasterDefinition>
>   </complexType>
>   </SchemaMapping>
>   </fdo:DataStore>
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/Raster-Config-XML-File-tp18445587p18447942.html
