[mapguide-users] SQL Server 2008 Spatial Data not Displaying in Open Source Viewers
Rock Beans rockbeans at gmail.com
Wed Jul 16 17:30:49 EDT 2008
I figured out the issue. The Initial Extents are not calculating
automatically. I had to manually enter in the Upper/Lower X/Y values then
everything worked as planned. This would be a nice feature as other layers
when put into a new map automatically figure these things out. So basically
none of the previews work till you get to the map and set these values.
There would be no way to preview a layer with this issue. Is this a bug, if
so should it be added to bug trac?
The Rock
PS Why do I get this every reply?
Mail Delivery SystemThis is the Postfix program at host lists.osgeo.org.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
On Wed, Jul 16, 2008 at 1:55 PM, Brent Robinson <brent.robinson at autodesk.com>
wrote:
>  Hi Rock,
> Do any messages show up in Error.log?
> Brent.
> *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Rock Beans
> *Sent:* Wednesday, July 16, 2008 2:33 PM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] SQL Server 2008 Spatial Data not Displaying in
> Open Source Viewers
> I have MapGuide Studio 2009 creating the SQL data connection successfully.
> I have layers being created from that data connection with the SDE object I
> specify, for example, county polygons. Only problem is when previewing data,
> layers, maps or layouts both old and new flex style nothing shows up. The
> legend is populated correctly. I am using a dataset that is LL83 so there
> should not be a coordinate system issue. Anyone have any ideas or will this
> not work yet as it is very new technology.
> Side Note: I have it working in Map 2009 as far as bulk copy and then later
> display that data right from SQL Server. Is this going to be a limitation to
> the Open Source version. In other words withh Map Guide Enterprise be
> required?
> The Rock
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080716/ea8d9724/attachment.html
