[mapguide-users] Using .NET Api to connect from a different Machine
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Jul 17 10:21:00 EDT 2008
AFAIK, it should work then.
Do you have both port 2812 and 2811 open on both machines?
Since you are using .Net, you could also use the Web API.
I have wrapped most of the calls in the MaestroAPI, so they appear to be
native .Net classes:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI
Regards, Kenneth Skovhede, GEOGRAF A/S
Johann Nothbauer skrev:
> Hi Kenneth!
> Thank you for your fast answer.
> I already changed the IpAdress in the "webconfig.ini" file. The
> MGSiteConnection works perfectly. It's the Resource-Service that I
> can't connect to (MgConnectionFailedException). Do you know which
> files I have to copy for to use the Resource Service?
> Thany yo for the warning, I am absolutely aware of the security
> issues. My solution is designed for administrative access over local
> LAN only.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> The file "webconfig.ini" must be changed to point to the correct
>> server instead of "127.0.0.1".
>> Its under the section [SiteConnectionProperties]
>> IpAddress                          =127.0.0.1
>> Port                               = 2812
>> You might also have to copy some of the folders referenced in there,
>> depending on what you want to do.
>> I would not recommend doing this over the internet, because the data
>> transmitted over the wire ends up in the MapGuide server process
>> which runs in the "Local System Account".
>>> Hi all!
>>> I'm trying to use the .NET Api to establish a connection to a
>>> Mapguide 2.0.1 Site without using a Web Viewer. My Application is a
>>> smart client and should run on a different Machine the MapGuide
>>> Server runs on.
>>> So I tried the following (in a Winforms Button_Click):
>>> MapGuideApi.MgInitializeWebTier("webconfig.ini");
>>> // Connect to the site.
>>> MgUserInformation userInfo = new MgUserInformation("Administrator",
>>> "admin");
>>> MgSiteConnection siteConnection = new MgSiteConnection();
>>> siteConnection.Open(userInfo);
>>> MgResourceService resService =
>>> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
>>> This works so far, but when I try to use the Resource-Service like
>>> this:
>>> MgResourceIdentifier resID = new MgResourceIdentifier("Library://");
>>> MgByteReader resEnum = resService.EnumerateResources(resID, -1, "");
>>> the API throws get an "OSGeo.MapGuide.MgConnectionFailedException"
>>> (Message: "Cannot establish connection").
>>> The same code works on the MapGuide Server Machine.
>>> Is it possible to use the API to connect to a Mapguide Server on a
>>> different machine? Or do I have to use the Web-API (XML) over HTTP?
>>> I can change all my firewall rules, no problem.
>>> Any Ideas?
>>> Thanx,
>>> Nothi
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
