[mapguide-users] Upgrade to 2.0 Question
George McLean gmclean at gorge.net
Thu Jul 17 16:33:17 EDT 2008
I tried Andy's suggestion and it appears to have worked well.
Thanks!
George
Dave Wilson wrote:
> The upgrade modifies the indexes and the database, not the data per se so an import of the package to an empty Repository doesn't modify the data as far as I know and doesn't require the upgrade scripts to be run.
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
> Sent: Thursday, July 17, 2008 12:27 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Upgrade to 2.0 Question
> I didn't when I upgraded my sites.  I think the only time it is required
> is when you upgrade in place.
> Martin
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy
> Morsell
> Sent: Thursday, July 17, 2008 2:21 PM
> To: 'MapGuide Users Mail List'
> That is confusing then.  I've upgraded several sites by exporting /
> importing the packages without running any batch files and everything
> works
> fine.  My assumption was that the package import process on the 2.0
> server
> handled everything and converted it properly.  I would also be
> interested in
> a confirmation about the proper way to upgrade.
> Andy
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren
> Medernach
> Sent: Thursday, July 17, 2008 9:42 AM
> I've also been told (sorry, can't remember where or who) that if you
> load a package from a previous release you should also run the
> UpgradeRepositories.bat & SetupRepositoryIndices.bat batch files located
> in the ..\Server\RepositoryAdmin folder.
> Can somebody verify that this is a required step?
> Warren M
> Morsell
> Sent: Thursday, July 17, 2008 10:35 AM
> I've personally found that the easiest way to upgrade is to first export
> a
> package of your ENTIRE 1.2 repository and then load that package into
> your
> 2.0 site.  You may want to re-install 1.2 somewhere, export your
> repository,
> then re-install 2.0 so that it's initially working and then load the
> package.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George
> McLean
> Sent: Thursday, July 17, 2008 9:20 AM
> Subject: [mapguide-users] Upgrade to 2.0 Question
> Hello,
> I have successfully upgraded a windows server 2003 system following the
> migration instructions.
> In attempting to upgrade an XP SP2 system I made a mistake and did not
> uninstall V1.2 before installing v2.0. I realized my mistake and
> uninstalled v1.2 and then v2.0. I then re-installed v2.0 but have not
> had much success.
> The Mapguide service will not start in a reboot of the system. I see
> errors in the error log indicating the repository version is incorrect
> (V5 instead of V6). I have tried running the UpgradeRepositories.bat but
> get errors upgrading the Site repository and Library repository stating
> the "Program version 4.5 doesn't match environment version ....". I have
> tried this with my 1.2 repositories and also with the repositories that
> are installed right from v2.0.
> I am guessing I have some registry setting or some environment variable
> that was not cleared out by the removal of v1.2 but I have not found
> anything.
> Any suggestions on how to clean this up and just install 2.o from
> scratch? I have my repositories from 1.2 backed up elsewhere.
> Thanks
> George McLean
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.5.0/1558 - Release Date: 7/17/2008 9:56 AM
