[mapguide-users] Mr Sid problems in MGOS 2.0
George McLean gmclean at gorge.net
Thu Jul 17 19:51:25 EDT 2008
Wow Jason, what a quick reply!
I guess I did not install the gdal1.4.dll, I did install the files as
outlined in the document you pointed me to. Sorry about the confusion.
I do see errors in the log indicating a coordinate system difference
between the sid file and the map. I am not sure how to do a coordinate
system override. Is there some documentation somewhere? I am using
Mapguide Studio 2007 to build my map and can not find any tools for
this. I do see some references to editing the config.xml file but any
guidance to documentation on how to modify this file would be much
appreciated.
Thanks again,
George
Jason Birch wrote:
> Hi George,
> The instructions for 2.0 (and 2.0.1) are somewhat different than for
> previous versions:
> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0
> You should not install gdal1.4.dll.  You should only need to install the
> three MrSID plugin files.
> However... If you're seeing the files opening, it may be that you're
> running into the problem with the coordinate system being set to a value
> other than that of the map, and may need to set a CS override in the
> data connection for the raster data.
> Are there any exceptions in your mapguide error log?
> Another possibility is that you're not in the right place when
> previewing the data. I think that the raster provider in 1.2 may have
> done a better job of reporting the extents of MrSID files.  This is just
> a gut feeling though; I haven't taken the time to test/document the
> problem.
> Jason
> -----Original Message-----
> From: George McLean
> Subject: [mapguide-users] Mr Sid problems in MGOS 2.0
> Hello, I have one last issue (I hope) upgrading to 2.0 from 1.2. I can
> not get my Mr Sid files to render in MG 2.0.
> I have installed the gdal1.4 dll and can see the files opening when
> running mgserver from a command window so I think I have the file paths
> correct. These sid files worked in MG 1.2.
> I see a lot of discussion regarding sid files and connection handles,
> memory issues etc. but I do not think I am even getting that far!
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.5.0/1558 - Release Date: 7/17/2008 9:56 AM
