[mapguide-users] Mr Sid problems in MGOS 2.0
George McLean gmclean at gorge.net
Thu Jul 17 22:32:40 EDT 2008
I got my sid files working after installing studio 2009 and setting the
CS overrides.
Thanks everyone for answering all my questions today!!
George
George McLean wrote:
> Wow Jason, what a quick reply!
> I guess I did not install the gdal1.4.dll, I did install the files as
> outlined in the document you pointed me to. Sorry about the confusion.
> I do see errors in the log indicating a coordinate system difference
> between the sid file and the map. I am not sure how to do a coordinate
> system override. Is there some documentation somewhere? I am using
> Mapguide Studio 2007 to build my map and can not find any tools for
> this. I do see some references to editing the config.xml file but any
> guidance to documentation on how to modify this file would be much
> appreciated.
> Thanks again,
> George
> Jason Birch wrote:
>> Hi George,
>> The instructions for 2.0 (and 2.0.1) are somewhat different than for
>> previous versions:
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#FDO3.3.0MapGuide2.0.0
>> You should not install gdal1.4.dll.  You should only need to install the
>> three MrSID plugin files.
>> However... If you're seeing the files opening, it may be that you're
>> running into the problem with the coordinate system being set to a value
>> other than that of the map, and may need to set a CS override in the
>> data connection for the raster data.
>> Are there any exceptions in your mapguide error log?
>> Another possibility is that you're not in the right place when
>> previewing the data. I think that the raster provider in 1.2 may have
>> done a better job of reporting the extents of MrSID files.  This is just
>> a gut feeling though; I haven't taken the time to test/document the
>> problem.
>> Jason
>> -----Original Message-----
>> From: George McLean
>> Subject: [mapguide-users] Mr Sid problems in MGOS 2.0
>> Hello, I have one last issue (I hope) upgrading to 2.0 from 1.2. I
>> can not get my Mr Sid files to render in MG 2.0.
>> I have installed the gdal1.4 dll and can see the files opening when
>> running mgserver from a command window so I think I have the file
>> paths correct. These sid files worked in MG 1.2.
>> I see a lot of discussion regarding sid files and connection handles,
>> memory issues etc. but I do not think I am even getting that far!
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> No virus found in this incoming message.
>> Checked by AVG - http://www.avg.com Version: 8.0.138 / Virus
>> Database: 270.5.0/1558 - Release Date: 7/17/2008 9:56 AM
> Checked by AVG - http://www.avg.com Version: 8.0.138 / Virus Database:
