[mapguide-users] Mr Sid problems in MGOS 2.0
Jason Birch Jason.Birch at nanaimo.ca
Fri Jul 18 01:12:06 EDT 2008
Good to hear that you managed to work your way through it...
Not that it really matters now that you have Studio 2009 installed, but MapGuide Maestro also provides the ability to set coordinate system overrides.  I also like the way that Maestro approaches the configuration of unmanaged raster files, and maintains inter-resource links when moving things around in the repository.
http://trac.osgeo.org/mapguide/wiki/maestro
Jason
Subject: Re: [mapguide-users] Mr Sid problems in MGOS 2.0
I got my sid files working after installing studio 2009 and setting the
CS overrides.
Thanks everyone for answering all my questions today!!
George
George McLean wrote:
> I do see errors in the log indicating a coordinate system difference
> between the sid file and the map. I am not sure how to do a coordinate
> system override. Is there some documentation somewhere? I am using
> Mapguide Studio 2007 to build my map and can not find any tools for
> this. I do see some references to editing the config.xml file but any
> guidance to documentation on how to modify this file would be much
> appreciated.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080717/6e164f37/attachment.bin
