[mapguide-users] MAESTRO and FDO
Edmondo edmondo.elisei at gmail.com
Fri Jul 18 04:57:03 EDT 2008
Edmondo wrote:
> Dear All,
> I have a .shp with parcels. I connected this file in MPG MAESTRO by FDO
> (unmanaged file... test connection works fine)
> and added the source to a layer, added the layer to a new map, made new
> layout.
> My browser doesn't show the map.
> Trying to add feature to display (area for example) MAESTRO returns an
> error,
> But it seems the shape is correct: I opened the file in ARCGIS and it
> contains areas and other metadata.
> I seen Seboyang data examples (there are only .sdf format) and the
> GEOMETRY field contains "SHPGEOMETRY" instead in with my shape
> the same field contains "GEOMETRY"
> Someone can explain me the correct way to add a shape?
> Sorry for my questions (and for my english), but I started with WEBGIS
> just few days ago.
> Thanks
> E.
http://www.nabble.com/file/p18525187/error.jpg
View this message in context: http://www.nabble.com/MAESTRO-and-FDO-tp18525059p18525187.html
