[mapguide-users] Mr Sid problems in MGOS 2.0
George McLean gmclean at gorge.net
Fri Jul 18 09:07:55 EDT 2008
Thanks Jason,
I will take a look at Maestro. It sounds like a good tool.
George
Jason Birch wrote:
> Good to hear that you managed to work your way through it...
> Not that it really matters now that you have Studio 2009 installed, but MapGuide Maestro also provides the ability to set coordinate system overrides.  I also like the way that Maestro approaches the configuration of unmanaged raster files, and maintains inter-resource links when moving things around in the repository.
> http://trac.osgeo.org/mapguide/wiki/maestro
> Jason
> ________________________________
> From: George McLean
> Subject: Re: [mapguide-users] Mr Sid problems in MGOS 2.0
> I got my sid files working after installing studio 2009 and setting the
> CS overrides.
> Thanks everyone for answering all my questions today!!
> George
> George McLean wrote:
>> I do see errors in the log indicating a coordinate system difference
>> between the sid file and the map. I am not sure how to do a coordinate
>> system override. Is there some documentation somewhere? I am using
>> Mapguide Studio 2007 to build my map and can not find any tools for
>> this. I do see some references to editing the config.xml file but any
>> guidance to documentation on how to modify this file would be much
>> appreciated.
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.5.1/1559 - Release Date: 7/17/2008 6:08 PM
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
