[mapguide-users] MySQL connection timing out
George McLean gmclean at gorge.net
Fri Jul 18 12:52:34 EDT 2008
I left my development server last night thinking things were in pretty
good shape but this morning when querying a map no features stored in
MySQL and rendered using FDO were displayed.
I see in Mapguide's error log that starting at 4:12AM the connection was
lost to MySQL. Restarting theMySQL service did not fix the problem but
restarting MG did.
I have never seen this with MG 1.2 that I am aware of. I see there are
settings in MySQL that can extend the connection timeout but I am not
sure if this is the best solution.
Has anyone else seen this issue and found a solution?
I am not sure I completely understand what is happening here. Does MG
make a leave a connection open to MySQL? Why would I get a query attempt
every hour as shown in the log below? My first attempt to render a map
occurred at 08:51:21 as show below but the connection was apparently
broken by then?
Thanks again,
George McLean
<2008-07-18T04:12:45>             Administrator
 Error: An exception occurred in FDO component.
        RDBMS: Lost connection to MySQL server during query
 StackTrace:
  - MgTimedEventHandler.handle_timeout line 123 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\core\TimedEventHandler.cpp
  - MgDataConnectionTimeoutEventHandler.HandleEvent line 89 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\core\DataConnectionTimeoutEventHandler.cpp
  - MgFdoConnectionManager.RemoveExpiredFdoConnections line 484 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\FdoConnectionManager.cpp
<2008-07-18T05:12:49>             Administrator
        RDBMS: MySQL server has gone away
 StackTrace:
<2008-07-18T06:12:45>             Administrator
 StackTrace:
<2008-07-18T07:12:45>             Administrator
 StackTrace:
<2008-07-18T08:12:45>             Administrator
 StackTrace:
<2008-07-18T08:51:21>         127.0.0.1    Administrator
 Error: Failed to stylize layer: Sectionalizer
 StackTrace:
  - MgMappingUtil.StylizeLayers line 775 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\mapping\MappingUtil.cpp
