[mapguide-users] MapGuide OS WMS server
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sun Jul 20 06:05:17 EDT 2008
Unfortunately that part of MapGuide is not yet supported by Maestro.
The easy way out, is to purchase MapGuide Studio.
The hard way is to retrieve and edit the Xml header information of the
layers.
Unfortunately Maestro does not support this either, so you will have to
do this manually
on the Http test form.
I have not worked enough with setting up a WMS service to guide you on
how to do it.
I did see a post a while back that had the correct Xml definition for
the resource header.
You can request that this is addressed in Maestro, by adding a ticket:
http://trac.osgeo.org/mapguide/newticket
(You must be logged in with an OSGeo ID)
Regards, Kenneth Skovhede, GEOGRAF A/S
Danas Augutis skrev:
> Thanks for links Gwenael, but I still don't understand.
> I was doing everything according our guides, but unfortunately i can not get
> layer properties in MapGuide Maestro. Its inactive.
> Is there any other way to set up WMS?
> On Friday 04 July 2008 00:30:13 Gwenael Bachelot wrote:
>> Hi Danas,
>> I am not sure it is what you are searching for, but I wrote on my blog two
>> posts on how to publish WMS with MapGuide (using Autodesk MapGuide Studio).
>> It's in french, but with Google translation (on the left), and screenshots,
>> I assume it can be useful. You will find :
>> - publish WGS 84 WMS service :
>> http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des-do
>> n.html - publish with other coordsys :
>> http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des-d-
>> 1.html
>> Cordialement,
>> Gwenael
>> Gwenael Bachelot - Mailto:gwenael.bachelot at autodesk.com
>>       http://blogs.autodesk.com/geospatialfrance
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Danas Augutis
>> Sent: jeudi 3 juillet 2008 15:21
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] MapGuide OS WMS server
>> I'm not used to mapguide studio, I found 'is published check box, but was
>> unable to save layer after checking it (save was not active).
>> Is it somewhere in XML files of layers? I didn't found anything special in
>> sheboygan layers. Can you send my an example of publishing code, please?
>> Regards,
>> D.
>> On Thursday 03 July 2008 12:52:07 Zac Spitzer wrote:
>>> there's an is_published flag on the resource header for mapguide
>>> layers which when set
>>> exposes them via WMS... mapguide studio makes it easier
>>> if you look at the headers for the sheboygan layers you will see the
>>> setting in the xml
>>> z
>>> On Thu, Jul 3, 2008 at 7:48 PM, Dumas A <dumas65 at gmail.com> wrote:
>>>> I'm looking for info about wms services on MGOS. I'm interested to
>>>> provide some data via WMS.
>>>> I can see sheboygan example data in ArcCatalog using WMS, but none of
>>>> my Datasets are in server. Can you tell me where sheboygan example data
>>>> for WMS is configured? How to configure WMS server for Onw data?
>>>> Any help appritiated!
>>>> D.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080720/d542e983/attachment.html
