[mapguide-users] MapGuide OS WMS server
Danas Augutis dumas65 at gmail.com
Mon Jul 21 03:25:31 EDT 2008
I found It it's EPSG:3346
On Sunday 20 July 2008 13:05:17 Kenneth Skovhede, GEOGRAF A/S wrote:
> Unfortunately that part of MapGuide is not yet supported by Maestro.
> The easy way out, is to purchase MapGuide Studio.
> The hard way is to retrieve and edit the Xml header information of the
> layers.
> Unfortunately Maestro does not support this either, so you will have to
> do this manually
> on the Http test form.
> I have not worked enough with setting up a WMS service to guide you on
> how to do it.
> I did see a post a while back that had the correct Xml definition for
> the resource header.
> You can request that this is addressed in Maestro, by adding a ticket:
> http://trac.osgeo.org/mapguide/newticket
> (You must be logged in with an OSGeo ID)
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Danas Augutis skrev:
> > Thanks for links Gwenael, but I still don't understand.
> > I was doing everything according our guides, but unfortunately i can not
> > get layer properties in MapGuide Maestro. Its inactive.
> > Is there any other way to set up WMS?
> > On Friday 04 July 2008 00:30:13 Gwenael Bachelot wrote:
> >> Hi Danas,
> >> I am not sure it is what you are searching for, but I wrote on my blog
> >> two posts on how to publish WMS with MapGuide (using Autodesk MapGuide
> >> Studio). It's in french, but with Google translation (on the left), and
> >> screenshots, I assume it can be useful. You will find :
> >> - publish WGS 84 WMS service :
> >> http://geospatialfrance.typepad.com/geospatialfrance/2008/06/publier-des
> >>-do n.html - publish with other coordsys :
> >>-d- 1.html
> >> Cordialement,
> >> Gwenael
> >> Gwenael Bachelot - Mailto:gwenael.bachelot at autodesk.com
> >>       http://blogs.autodesk.com/geospatialfrance
> >> -----Original Message-----
> >> From: mapguide-users-bounces at lists.osgeo.org
> >> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Danas
> >> Augutis Sent: jeudi 3 juillet 2008 15:21
> >> To: MapGuide Users Mail List
> >> Subject: Re: [mapguide-users] MapGuide OS WMS server
> >> I'm not used to mapguide studio, I found 'is published check box, but
> >> was unable to save layer after checking it (save was not active).
> >> Is it somewhere in XML files of layers? I didn't found anything special
> >> in sheboygan layers. Can you send my an example of publishing code,
> >> please?
> >> Regards,
> >> D.
> >> On Thursday 03 July 2008 12:52:07 Zac Spitzer wrote:
> >>> there's an is_published flag on the resource header for mapguide
> >>> layers which when set
> >>> exposes them via WMS... mapguide studio makes it easier
> >>> if you look at the headers for the sheboygan layers you will see the
> >>> setting in the xml
> >>> z
> >>> On Thu, Jul 3, 2008 at 7:48 PM, Dumas A <dumas65 at gmail.com> wrote:
> >>>> I'm looking for info about wms services on MGOS. I'm interested to
> >>>> provide some data via WMS.
> >>>> I can see sheboygan example data in ArcCatalog using WMS, but none of
> >>>> my Datasets are in server. Can you tell me where sheboygan example
> >>>> data for WMS is configured? How to configure WMS server for Onw data?
> >>>> Any help appritiated!
> >>>> D.
> >>>> _______________________________________________
> >>>> mapguide-users mailing list
> >>>> mapguide-users at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
