[mapguide-users] Is it possible to create join on join ?
David Nuell nuell at nicholsenvironmental.com
Wed Jul 23 12:07:33 EDT 2008
Krunoslav -
I do not believe that it is possible.  I also tried this a while back and
was frustrated that it could not be done.  One solution that was given was
to create a query that encapsulates all the records you want in all tables
then join that query to your initial table/file.
Cheers.
Krunoslav wrote:
> For example, 3 tables:
> Table1 <-> Table2 = Join1
> This is ok, i understand this. Is it possible to join Join1 with Table3 ?
> This are tables from OracleXE, and I can join first two tables, but when I
> create New Join, I cannot select this Join1 as primary join source. How to
> do this?
View this message in context: http://www.nabble.com/Is-it-possible-to-create-join-on-join---tp18608710p18614422.html
