[mapguide-users] Is it possible to create join on join ?
Dave Wilson dave.wilson at autodesk.com
Wed Jul 23 12:42:48 EDT 2008
For performance reasons if you are querying 2 tables on the same instance it's much faster to create a view in the database than do a second join which isn't currently supported anyway.
The use case that isn't currently handled is when you have 2 tables on 2 different database instances or even platforms. Although in some cases it's possible to implement a view on the database that queries both Oracle and SQL Server for example.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Nuell
Sent: Wednesday, July 23, 2008 10:08 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Is it possible to create join on join ?
Krunoslav -
I do not believe that it is possible.  I also tried this a while back and
was frustrated that it could not be done.  One solution that was given was
to create a query that encapsulates all the records you want in all tables
then join that query to your initial table/file.
Cheers.
Krunoslav wrote:
> For example, 3 tables:
> Table1 <-> Table2 = Join1
> This is ok, i understand this. Is it possible to join Join1 with Table3 ?
> This are tables from OracleXE, and I can join first two tables, but when I
> create New Join, I cannot select this Join1 as primary join source. How to
> do this?
View this message in context: http://www.nabble.com/Is-it-possible-to-create-join-on-join---tp18608710p18614422.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
