[mapguide-users] Firefox 3 intermittent raster display
Zac Spitzer zac.spitzer at gmail.com
Thu Jul 24 08:35:49 EDT 2008
As far as i could tell the raster's loaded ok, it's a little hard to
tell without knowing the map,
but here were no glaring holes from missing rasters
just on the initial load i got the following error
Error: reqParams is not defined
Source file: http://maps.northumberlandnationalpark.org.uk/mapguide/mapviewerajax/mapframe.php?MAPDEFINITION=Library%3A%2F%2FMaps%2FNNPA.MapDefinition&TYPE=HTML&SHOWLEGEND=1&SHOWPROP=1&INFOWIDTH=200&LOCALE=en&HLTGT=2&HLTGTNAME=&SHOWSLIDER=1&SESSION=c7957c60-ffff-ffff-8000-0030059aac87_en_7F0000010AFC0AFB0AFA
Line: 3265
also
Error: parent.InMeasure is not a function
Line: 3265
Z
On Thu, Jul 24, 2008 at 10:29 PM, Tom Chadwin <tom.chadwin at nnpa.org.uk> wrote:
> zspitzer wrote:
>> Have you tried using fiddler to see if any http errors are occuring?
> All results are 200 - no sign of any problem.
> zspitzer wrote:
>> nothing in the mapguide or webserver error logs
> Nothing that I can see, no.
> zspitzer wrote:
>> I am seeing some javascript errors with FF3
> I am not seeing them. How are you triggering them?
> Any other ideas? Just to check: are you seeing the same behaviour as me?
> T
> View this message in context: http://www.nabble.com/Firefox-3-intermittent-raster-display-tp18629834p18630899.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
