[mapguide-users] make a table from query example
lolob azzam_wahab at hotmail.com
Fri Jul 25 00:33:59 EDT 2008
Hello list,
First of all, I'm not really good in php..and I have something to ask about
part of the codes below..
http://www.nabble.com/file/p18645057/codes.jpg
Basically, what I want to do is to make a table after I hit the execute
button.Please see the image below.
http://www.nabble.com/file/p18645057/query_result.jpg
It works and brings out all the fields/properties from the select layer..If
you see in the codes, I have assign the variable earlier..How do I make the
$displayValue to display all the value from all fields of the select
layer..Please help,thanks.
View this message in context: http://www.nabble.com/make-a-table-from-query-example-tp18645057p18645057.html
