[mapguide-users] Work with data from Oracle Spatial
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jul 25 03:38:04 EDT 2008
If you use Maestro, you should only have to set the "Service" field to
the TNS name,
and "Schema" to the database schema, and then it should work.
I think the error is equvalent to a "Unknown error occured" message.
Regards, Kenneth Skovhede, GEOGRAF A/S
A. Fischer skrev:
> Hello Community,
> I'm a very new user of MapGuide OS and have some problems with the import of
> my data.
> I use Oracle Spatial 10g.
> At first I tried it with the Web Studio
> (http://localhost:8008/mapguide/webstudio/) to import Feature Source but
> there I can use only SDF and SHP - data.
> Than I checked out the Maestro OS project. I used the following settings:
> Known connection type; Oracle (oracle driver) as database type;
> database=orcl
> and as specified credentials the database-login (don't know if it's right):
> When I clicked the "Test connection" butto I got this error:
> "The remote server returned an error: (559) MgFdoException.:
> An exception occurred in FDO component.
> RDBMS: No current open database.
> Exception occurred in method MgFdoConnectionManager.Open at line 858 in file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\FdoConnectionManager.cpp"
> I checked this file with Dependency Walker and find out that 2 *.dll-files
> were missing (Microsoft Visual C runtime). Well, I installed this and copied
> the ddl's but the connection still don't work.
> I would be pleased to receive a reply,
> Alex
