[mapguide-users] Work with data from Oracle Spatial
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jul 25 05:44:40 EDT 2008
Instead of using ODBC, you can use the Oracle provider.
The ODBC provider will only let you insert points, not lines or areas.
Regards, Kenneth Skovhede, GEOGRAF A/S
Alexander Fischer skrev:
> Thank you!
> First time, I tried those parameters, the connection test get no
> error. But although I couldn't work with it and now again and again
> the same error like before.
> I make an attachment with a picture of the connection settings. Maybe
> there is still a mistake?
> Kind regards, Alexander Fischer
> 2008/7/25 Kenneth Skovhede, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>>:
>     If you use Maestro, you should only have to set the "Service"
>     field to the TNS name,
>     and "Schema" to the database schema, and then it should work.
>     I think the error is equvalent to a "Unknown error occured" message.
>     A. Fischer skrev:
>         Hello Community,
>         I'm a very new user of MapGuide OS and have some problems with
>         the import of
>         my data.
>         I use Oracle Spatial 10g.
>         At first I tried it with the Web Studio
>         (http://localhost:8008/mapguide/webstudio/) to import Feature
>         Source but
>         there I can use only SDF and SHP - data.
>         Than I checked out the Maestro OS project. I used the
>         following settings:
>         Known connection type; Oracle (oracle driver) as database type;
>         database=orcl
>         and as specified credentials the database-login (don't know if
>         it's right):
>         When I clicked the "Test connection" butto I got this error:
>         "The remote server returned an error: (559) MgFdoException.:
>         An exception occurred in FDO component.
>         RDBMS: No current open database.  Exception occurred in method
>         MgFdoConnectionManager.Open at line 858 in file
>         d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\FdoConnectionManager.cpp"
>         I checked this file with Dependency Walker and find out that 2
>         *.dll-files
>         were missing (Microsoft Visual C runtime). Well, I installed
>         this and copied
>         the ddl's but the connection still don't work.
>         I would be pleased to receive a reply,
>         Alex
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
Skipped content of type multipart/related
