[mapguide-users] Loading large amount of raster Data within MG 2.0 with GDAL Provider
wkhattak Wajid.Khattak at keynetix.com
Fri Jul 25 07:31:51 EDT 2008
I am trying to run the server in interactive mode, however, it looks like
that the CPL_DEBUG environment var is not set up on my machine.If I want to
set it up manually, what should be its value?
regards,
Kenneth Skovhede, GEOGRAF A/S wrote:
> I'm pretty sure the tile index config file works for FDO 3.3.* as well.
> What errors are you getting? Have you tried the debug instructions to
> see if there are more errors?
> You can try to build an index file with Maestro, but you have to use the
> preview build (r3235)
> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
> After you build it, you can examine the config file, and see if any of
> the images failed.
> If they failed, they will have a bounding box of 1000000, 1000000,
> -1000000, -1000000.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> wkhattak skrev:
>> Hi,
>> I am having no success in loading a large amount of raster data using
>> GDAL
>> (3.3.0). On experimental basis, it works with a small amount of data (I
>> ahve
>> got tiff based images). I have also tried by creating the tile index
>> Config
>> file but it looks like that it only applies to 3.2.0. It's the same story
>> with Autodesk's raster provider, only works with a small amount of data.
>> regards,
>> W Khattak
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Loading-large-amount-of-raster-Data-within-MG-2.0-with-GDAL-Provider-tp18649325p18649943.html
