[mapguide-users] How do i load raster in MGOS 2?
jamesdudden jamesdudden at blueyonder.co.uk
Fri Jul 25 08:45:07 EDT 2008
Kenneth,
I di das you instructed and this is what i got:
(460) Server starting...
(460) PROJ4 Coordinate System Library
(460) Server started.
GDAL: Auto register C:\Program
Files\MapGuideOpenSource2.0\Server\Bin\gdalplugin
s\gdal_ECW.dll using GDALRegister_ECW.
s\gdal_MrSID.dll using GDALRegister_MrSID.
JPEG: Magic: 0x4949 <little-endian> Version: 0x2a
GDAL: GDALOpen(C:\Program
Files\Autodesk\MapGuideStudio2009\SampleData\Raster/RA
STER.jpg) succeeds as JPEG.
Files\Autodesk\MapGuideStudio2009\SampleData\Raster/Sh
eboygan_000_000.tif) succeeds as GTiff.
eboygan_000_001.tif) succeeds as GTiff.
eboygan_001_000.png) succeeds as PNG.
GDAL: GDALClose(C:\Program
heboygan_000_001.tif)
eboygan_001_000.tif) succeeds as GTiff.
heboygan_001_000.png)
eboygan_001_001.tif) succeeds as GTiff.
heboygan_001_000.tif)
There doesn't seem to be any obvious errors - can you suggest anything else?
Thank you for your help
james Dudden
In that case, you should follow the instructions for debugging rasters:
http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#DebuggingRastersinMapGuide
Regards, Kenneth Skovhede, GEOGRAF A/S
View this message in context: http://www.nabble.com/How-do-i-load-raster-in-MGOS-2--tp18648843p18651030.html
