[mapguide-users] MSSQL 2000 Support
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jul 28 03:05:58 EDT 2008
There is also an Open Source provider for spatially enabled MSSQL 2008:
http://fdo.osgeo.org/content/fdo-331-downloads
I'm not sure how well it works, or if it works with MSSQL 2000.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jackie C. Ng skrev:
> You can only connect to a MSSQL 2000 database using the ODBC FDO provider,
> meaning you can only use the database for points, or for feature joins.
> If you want to use MSSQL 2000 as a spatially-enabled database, I think you
> will need the Enterprise version as that has a provider (Autodesk.SqlServer
> provider) for such functionality.
> - Jackie
> jkattampally wrote:
>> Hi,
>> Is there anyone out there using MSSQL 2000 as the data repository for MGOS
>> 2.0?. Just wanted to make sure MGOS 2.0 can connect to MSSQL 2000 with out
>> any problems. Would it need any additional config. or plugin, to make it
>> connect or can it connect with the basic windows install?
>> Thanks
>> Joe
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080728/bb313f58/attachment.html
